toyota 22re turbo
Old Mar 1, 2008 | 11:11 PM
84 yota ex-cab's Avatar
toyota 22re turbo
I have an 89 toyota with a 22re and i am looking to turbo it. Has anyone done this? Ifso, what all did you do to the motor as far as pistons, injectors, fuel delivery, boost, ecu?
Thanks for any help
Old Mar 1, 2008 | 11:15 PM
91Toyota's Avatar
yeah...it's been done...http://www.toyotacatalog.net/M1WebGe...1-CA0193D97924
Old Mar 2, 2008 | 06:57 AM
mistreatedtoys's Avatar
It sure would be easier to rebuid a 22ret than try to swap yours over, I have all you need to do it just sitting in my shed waiting.
Old Mar 3, 2008 | 10:16 AM
dcg9381's Avatar
Check the forum at:
www.22rte-trucks.com - there are several converted-to-turbo vehicles over there. Lots of options.
Thanks for any help
Pistons: JE pistons, custom sized, forged, 8.5:1 CR. If I was doing it again, I'd go to lower compression.
Injectors: 440 cc from a 7MGTE supra. I need to go to larger injectors, I have 530cc from an 87-88 RX72 turbo II waiting on install.
Fuel delivery: Walbro 255 LPH pump. Honestly, the stock fuel pump is adequate for use under 200hp.
Boost: Configureable. Today, 11psi at the compressor, 9psi at the manifold. 93 octane.
ECU: Megasquirt - and megasquirt to stock wiring adapter harness. No AFM.
MMA_Alex
25
Apr 18, 2017 05:07 AM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
