question about the fan on a 22re
Old Feb 15, 2008 | 03:23 PM
jury's Avatar
My 4runner started overheating and i was looking around the engine and knoticed the belt for the alt. was gone, it looks like it also goes to the pully on the fan, my question is when the fan is spinning is it turning gears/impeller in the water pump?? I hope the new belt will fix it, thanks for the help
Old Feb 15, 2008 | 03:25 PM
thook's Avatar
Yeppers.
Old Feb 15, 2008 | 03:30 PM
jury's Avatar
coolio thanks
Old Feb 15, 2008 | 03:51 PM
jury's Avatar
another question... the alt belt is on the last pully on the crank do you have to take all 3 off to be able to slide it on? the timing plate is in the way... thanks
Old Feb 15, 2008 | 04:05 PM
jury's Avatar
nevermind i see theres bolts on the timing plate, looks like its goin to be a pain in the dick any suggestions
Old Feb 15, 2008 | 04:53 PM
thook's Avatar
Timing plate? What do you mean? You shouldn't have to take anything off except the two belt in front of it.
Take off the a/c and power steering belts, slide them over the fan, slide the new alt. belt over the fan and onto the pulley and alt. Then, replace the other two belts.
Old Feb 15, 2008 | 05:54 PM
jury's Avatar
this timing plate thats over the 3rd pully (arrow to it)
Old Feb 15, 2008 | 06:00 PM
stupid_mud_gremlins's Avatar
check to make sure where the belt goes...that may go between. Seems like quite a pain to make it so it has to come off to change a belt...
Old Feb 15, 2008 | 06:03 PM
jasond's Avatar
You dont need to take off that "timing plate" the belt dosent touch it or anything, it just sits in between the gaps, if that makes sense.
Old Feb 15, 2008 | 06:08 PM
SCYOTA's Avatar
^^^Yep ^^^ The belt does not go underneath the "timing plate." The belt only contacts the bottom side of the crank pulley.
Old Feb 15, 2008 | 11:58 PM
jury's Avatar
ahhh i get it, thanks for the replys
the1998sr5
15
Jul 14, 2020 08:35 PM
coleypull15
Nov 3, 2015 07:41 AM
coryc85
Sep 9, 2015 06:24 AM
1996Taco
Jul 20, 2015 12:02 AM
zd92655
Jul 5, 2015 04:25 PM
