4 runner power issues
Old Feb 10, 2008 | 10:35 AM
kswann's Avatar
Question 4 runner power issues
I have a 1988 4runner 22re auto trans with 31/10.5/15 mastercraft concourse mt tires
the truck is stock. the problem i have is that the it feels like it has no power when i take off in drive and it idles alittle rough. i have change all fluids and changed plugs wires and cap and rotor button did not fix problem. i need help!!!!
Old Feb 10, 2008 | 10:39 AM
sloppy85toy's Avatar
check your timing,maybe your fuel filter
Old Feb 10, 2008 | 10:49 AM
JohnnyRanger54's Avatar
A compression check, will tell you everything you DONT really want to know.. Its easy, cheap, and will rule out, or rule in major issues very quickly....
Old Feb 10, 2008 | 11:24 AM
yarosig's Avatar
Try resetting your ECU via disconnecting your battery for 15 min.
Old Feb 10, 2008 | 12:01 PM
GoFish's Avatar
I had this problem with my 87 auto and I found a crack in the tube between the air box and the intake manifold.
Old Feb 10, 2008 | 03:21 PM
kswann's Avatar
Thank You This Will Give Me A Good Place To Start.
Old Feb 10, 2008 | 03:28 PM
TORTIS's Avatar
put some 4.88 gears in it. also ohm your coil to see if it is going out.
Old Feb 18, 2008 | 03:33 PM
kswann's Avatar
Angry gp sorsen distributor cap issue
found the problem it was a bad distributor cap and bad fuel injector. thanks for the help. I did find out that the distributor cap i used in the tune up was made by gp sorsen that it was cracked in three places went back to the parts house and found the rest they had where crack the same way this is a maufacture problem keep an eye out for this..
Old Feb 18, 2008 | 05:25 PM
312necro213's Avatar
My mom had a vw bug that she drove the urination out of, after 401k miles (it was a 69) it started running irradically and failing at idle, so me and my father were trying to assess the situation and eventually we just started it and pinned the throttle and a HUGE black / white cloud of smoke came out the back and it blew all this out it was crazy. What we figured happened was that she drives like a grandma never going above 3k rpm and so when we pinned it, it broke all the carbon crap out and blew out the engine, quite an experience.
voiddweller
19
May 2, 2016 09:10 PM
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
sharrack
Jun 26, 2015 09:33 AM
WI Girl
Jun 25, 2015 03:45 AM
bobbybouche
Jun 18, 2015 10:22 AM
