2ltd exhaust.
2ltd exhaust.
Hi.
I'm going to put a new exhaust thru my 2.4ltd surf,
I'm just trying to figur out what size to go with, 2.5 or 3''.
im also thinking about putting twin exsaust in, I would like them to exit before the rear wheels tho, Is this possible?,
If not I will just make them exit just after the wheels.
Reason for changing exhaust is because i do not want to over heat my engine.
Any feed back would be good Thanks.
Nooby from nz
Nooby from nz
Dude, he has a Turbo Diesel. You should go to a 3", I have just a turbo on mine and that is what i will run. If you want to lower your EGTs you need to let the exhaust flow more effeciently and fast as possible.
Exactly... With a diesel you could 3 or even 3.5 if you wanted to with no cat or muffler and still gain performance...
Some of the big fords around here are running 4" into a 6" tip on the 6L diesels. You don't want backpressure after the turbo.
you still want a smooth exhaust flow. a 6L engine is signifigantly larger than what we're talking about.
Your best bet would be to try a toyota diesel forum. There are only a couple guys on here with diesels
hhmm, too big of an exhaust is bad and too small of an exhaust is bad. This might seem stupidly simple minded of me, but how about pulling the exhaust manifold, measuring the outlet on the turbo and using the next biggest size tube you can find. Just an idea.
EGT = pyrometer. Check www.gaugepods.com - they make the least expensive one that I've seen and it works well.
My bad. I forgot you had a turbo diesel. Go for 3", and do some stacks.
go for 3" even if that's not the optimal amount, it would still cut costs down, and be much better than stock exhaust.
