Need help finding a vacuum line that feeds all 6 cylinders in my '95 4Runner
I bought a can of Seafoam Deep Creep to spray in my '95 4Runner since it's got a rough idle and the can of Deep Creep is supposed to help remove the builtup carbon deposits and hopefully fix my rough idle problem or at least improve it. The Seafoam Deep Creep website states "With engine warm, keep on high idle and spray through vacuum lines that feed all cylinders. I also found an instructional video clip from the makers of Deep Creep at the following website:
http://videos.streetfire.net/search/...6600e99b6f.htm
The man in the instructional video says to "spray directly into the intake manifold via the booster hose that goes to the brake", he then says it's also a vacuum hose. I took 3 pics of my engine and posted them below. I'm hoping someone could point out which hose I should be spraying the Deep Creep in.
Brake booster line.
In the middle photo, in the top right corner (roughly) is your master cyclider. The bigger vacuum hose with the clamp on it is the one that goes from the master cylinder left.
zd92655
Mar 6, 2022 12:58 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
