Timing Troubleshooting - LOST !!!!
OK heres the info:
1986 22re 4 runner
New engine
And here is the problem:
1) No timing adjustment.........No change when the Jumper is on although it does trigger the check engine light.
2) So I check and adjust the TPS - OK
3) So I check the AFM - OK
4) So I check the EFI relay - OK
5) So I check the Control relay - OK
6) I had to jump the Fuel pump jumper to get power to the fuel pump.
7) The truck starts and runs, I just cant get the darn thing to time correctly.......
I will be doing some more tests tonight (ECU power), just looking for some info / advice.
Thx, D
"pete f passed away quietly in his sleep on July 13, 2008
OK heres the info:
1986 22re 4 runner
New engine
Thx, D
No problem getting the timing mark to show up......the timing is close just dont know what it is.......main concern is why all the other items are not working...ie: the Jumper ???????
By jumping the fuel pump pigtail does this then bypass the other jumper T/E ?
I know I need to check for power at the ECU....but from the key on position, what order does the system go........I feel like I just keep going in a circle.........
PS: I have no clue if any of the items worked prior to pulling the motor.....bought it DOA......
Gotta head out to a job, Ill check back this afternoon...
Thx, agn... D
Thx, agn... D
im curious on the problem....
when i checked my timing last year, i found it was doing the same thing as yours. with the jumper, no change in timing like the FSM says.
hope someone knows whats goin on. since mine runs fine, i kinda forgot about it till now.
Sounds alot like my 86 22re 4runner. Just bought it with all new drive line, Starts and runs, but coughs and sputters BAD when driving. My distributor has about 1 1/2 in of adjustment, but that hasn't helped me either.
Are you throwing any codes? I have a 21 and a 52. the 52 is sometimes. I changed my O2 sensor with no gain, actually I still have the 21 code.
My mechanic friend said you have to disconnect a wire from the ECU to adjust the timing or the car won't recognize the adjustment. I don't know, but it's something to look in to.
I also read on another web site that in one guys case, the chain adjuster had broken , allowing the chain to jump a few teeth. I hope this isn't your or my fate. I will keep an eye on your thread for help and put in my 2 cents worth with any more discoveries. Feel free to check out mine too.
I am pretty sure the only thing that controls the base timing is the TPS Te1-idle switch. If that is not closed you will not get base. You always get a service light when you jump the diag terminals.
Those two terminals (TE1-E1) bypass the ECM timing advance. The terminals for the fuel pump only go the fuel pump (Fp) and battery positive (B+).
Maybe the diagnostic box is having issues. I'd suggest trying to jump the same terminals at the back of the ECM itself, but I don't how safe or effective it is. Seems like it would be fine, but...
Maybe test the TPS circuit at the back of the ECM connector. See if all is reading well.
Where does the timing sit without the jumper?
Does the CEL come on with the jumper?
There's no wire to disconnect from the ECM to adjust the timing during the adjustment process. You can't anyway, really. You want the ECM to read everything (sensors, etc.), just not be able to advance the timing.
That terminal box is coated with some funkey crap by Toyota. I cleaned mine with carb cleaner and a tooth brush. I was having similar problems jumping those pins with a thick wire. When finished, I sprayed over the contacts with a light oil. As for the TPS sticking, I had that problem too. Ordered a new TPS from a Toyota dealer in Dallas TX, got the replacement part number, and between cleaning the terminals and carefully installing the new TPS the truck really calmed down and the timing could be set.
My $0.02
My $0.02
I haven't been able to get back to it all week....... Great now ya talked me into firing up the burner.....#*&%#! $4.00 a gal Kerosene !!!!!
Thx, for the input ....just need to warm up a bit......see what I find tonight..
yeah its the tbs man mine was the same so i re adjed it with the body off the intake much much easier to work with then just used a mm and set it just right all in the heat of my house then froze putting it back on lol
Well I guess if you mess with it long enough things just start working????
Tested circuits and wiggled wires way to long last night, rechecked everything again today. Reset the TPS AGAIN !
Fuel pump circuit seems to work without the jumper now also....
Timing now at 5 goes to bout 12 with out the jumper. Runs good in the shop, have yet to get it out and put a load on it.
I guess if all else fails just take it all apart and put it back together a few times.......tada its FIXED ??????
jerusry
Oct 19, 2015 05:28 PM
Avenged
Jul 9, 2015 07:55 AM
Suprarossa
Jul 6, 2015 05:21 AM
