stock gears & 33's
Old Dec 26, 2007 | 05:50 PM
tank1's Avatar
stock gears & 33's
performance wise hows it going to be running 33x10.50 bfg mt on stocks and keeping the stock gearing of 4:10?????this is a 4cyl 5sp......this is a dd and a hunting truck.....
Old Dec 26, 2007 | 05:57 PM
Jay351's Avatar
You will defantly feel it, I wouldnt recomend it if its a DD.
Old Dec 26, 2007 | 06:03 PM
seanz0rz's Avatar
Guest
i run 33's on stock 4.10's,
i get great gas mileage on the freeway, 65 is achieved at 1800-1900 RPM. offroad, its not bad, just alot more 4lo.
acceleration SUCKS, but i dont drive fast anyway, i drive like my 90 year old grandmother!
bottom line, its ok, you might want to try it, if you cant stand it, you can always regear.
Old Dec 26, 2007 | 06:04 PM
Djlarroc's Avatar
Yup. I wouldn't either. I went as far as trading my new set of 33" wheels and tires to down grade to 31" and some cash. I'm gona use that cash for some lockers.
Old Dec 26, 2007 | 06:07 PM
tank1's Avatar
maybe i should just go with 31x10.5 bfg mt ....money saved will get me the aussie locker!!!!!That will probably be the best way to go for now...
Old Dec 26, 2007 | 06:12 PM
black diamond's Avatar
go with the 33's and the aussie, i run 35's with them gears for now, no problem, will re gear when i can$$$$
Old Dec 26, 2007 | 06:32 PM
aaronk's Avatar
My 22RE with a 5spd is a slug with 31's, I can't imagine what 33's would be like.
Old Dec 26, 2007 | 06:36 PM
tank1's Avatar
yeah boys think ill just go with the 31's,,thanks for info i guess it was just wishful thinking..... but aussie for sure!!!!!!
booo... my 22re does a good job!!!!!!!!!!!
Old Dec 26, 2007 | 06:40 PM
tank1's Avatar
yeah but i got to drive it everyday too,,,,i know i sure been thinking hard on the 33's but might wait...
Old Dec 26, 2007 | 06:43 PM
Old Dec 26, 2007 | 06:48 PM
yotasavg's Avatar
i didn't think third gens came with 4.10's..........
Old Dec 26, 2007 | 06:53 PM
tank1's Avatar
i got a 94 and for all the decoding i have done from the sticker onthe door jam it goes with 4:10...but sticker could be wrong..
Old Dec 26, 2007 | 06:54 PM
yotasavg's Avatar
no no, YOU have 4.10's. i mean't they third gen 4runner that i quoted. sorry for the confusion.
Old Dec 26, 2007 | 07:17 PM
sh0kk86's Avatar
i have 4.10's and 33's and get about 11mpg city, rarely drive freeway.
offroad i dont notice it once i get into 4lo.
if i had the chance id still do it. the advantages of it far outweigh the negatives for me.
Old Dec 26, 2007 | 07:25 PM
Djlarroc's Avatar
tank1, you are doing the right thing. Believe me. I've read just about every post on here regarding that stuff and had a long thread called "how much did you spend on regearing". Look it up. You are doing the right thing. You stick to that plan and use the extra tire money & regear money for a locker and sliders and you will wheel right by all these cats w/33" +, lifts & open diffs.
Old Dec 26, 2007 | 07:40 PM
ovrrdrive's Avatar
My 32's were quite painful for daily driving on the 4.10's but I did it anyway for about 10 years or so. I wouldn't recommend it to anyone but obviously depending on your level of tolerance it's possible and doable.
Old Dec 26, 2007 | 07:52 PM
shaeff's Avatar
i completely revised my plan a few weeks ago. i was going to get 33x10.5 BFG MT's instead of 31's. with my stock 22re, and 4.10's, i knew i'd want to kill myself. so instead, i'm going to save for the gears (4.88's, rear e-locker, front ARB) then save for the 33's, and do it all at once.
Old Dec 26, 2007 | 08:14 PM
seafarinman's Avatar
I ran 31's (31x10.5x15 2 sets, and then 31x12.5x15 1 set) on my 4.10 gears for 7 years. When I decided to SAS my rig, I decided to save $$$$ in the longrun and to only regear ONCE. So, I went with 5.29's and now I have 37" tires on my truck. Regearing is pretty expensive so I am only doing it once.
Before:
After:
Old Dec 26, 2007 | 08:29 PM
Asha'man's Avatar
Most of you are at sea level. Myself and Djlarroc are at 5,000 to 12,000 feet elevation, where oxygen is scarce. The old 22RE breathes even harder with big tires up here. Believe me, 31's are a chore on stock gears here, but even at sea level I still wouldn't go to 33's. Regear or stick with 31's.
