1/2 ton runningh gear under 83 pick up please help
i have an 83 toyota pickup with 9 inches off lift and i want to do all chevy running gear got a hole chevy truck for parts its complete need to know how to fit up and line up 1/2 ton running gear and whats needed thanks
Sounds like a cool project and a ton of work...
I would suggest that you check out this forum: http://www.pirate4x4.com/forum/forumdisplay.php?f=12
I think that you might be able to find some of your answers there as Pirate is more into that sort of mods...Good luck
sorry i dont have any pics basically i left the chevy axles uncut i also like the wide look. when i did my swap i used skymanufacturings toyota full width kit
I have 5inch toyota springsf&r than i used chevy u-bolts. i also invested in a set of crane high steer knuckles for the front axle that way it fixes the weak chevy knuckes. i did have to take and have brake lines made than i up graded to a chevy brake booster and master clinder and a wilwood proportioning valve cause i am running a set of 36s
where you located? If your going to pull your toyota gear out, people on here would take it, at least the front axle. First dibs though if your within 100 miles of me which your probably not.
these guys have a kit for full width sas
http://www.sky-manufacturing.com/
the1998sr5
15
Jul 14, 2020 08:35 PM
XtraCab
Apr 12, 2020 05:25 AM
skoti89
Jul 6, 2015 07:45 PM
save alot less work, this is coming from a guy that hates the wide/fullsize running gear look though.
