how can i flush out my wiper spray
Why do you want to flush it out? Is it dirty? Vinegar won't hurt it but I don't understand a need for that. If the tank is dirty just take it out and clean it up with a pipe brush, dish detergent and warm water.
Yep, CLR or LimeAway would do the trick. Probably best to pull the washer nozzles off the truck and soak them in some CLR or LA overnight, maybe sticking a pin into the nozzle to loosen up the crud.
I've used it to remove rust spots on paint before w/o issues. As long as it is not left on too long and washed off very well, it should be OK. Just don't want to let it dry on there, as the liquid evaporates, the phosphoric acid probably gets more concentrated.
make sure to start at the source, Take the bottle off first and clean it out real good. I personally would just buy all new rubber line, It cost a couple bucks(prob cheaper then a bottle of CLR) and is fairly easy to replace. then clean the nozzle out real good, you can just let em sit in warm water or blow em out, whatever works.
on that note, can you aim those nozzles? mine spray all over the top of the windshield and i have to run the wipers periodically for 5 minutes after using them cause of the drips. they'd work way better if they hit the middle of the windshield.
