swapped motor and now it runs like crap
Old Dec 5, 2007 | 11:51 PM
skife's Avatar
i blew up a 22RE and swapped it for another one, now it feels like the timing is off. it will run, but it won't run for crap, its got a miss and if you try to accelerate quickly it seems like it wants to stall out and misses, its fine if you just ease into the throttle though.
anyone else have this same problem?
Old Dec 6, 2007 | 12:26 AM
stormin94's Avatar
Clogged injectors???
Old Dec 6, 2007 | 11:20 AM
skife's Avatar
i don't think so, i swapped everything over from my other motor.
Old Dec 6, 2007 | 11:27 AM
keithguts's Avatar
Ya, I agree. Just because you put another motor in dosn't meen that the injectors are clean.
Old Dec 6, 2007 | 11:41 AM
skife's Avatar
even if they are the same injectors from the other motor?
i went from a EFI motor to a carbed motor with EFI on it.
Old Dec 6, 2007 | 11:48 AM
rdlsz24's Avatar
Did you set the timing on the new motor?
Rob
Old Dec 6, 2007 | 11:51 AM
keithguts's Avatar
are you saying that you used the injectors from the motor that you blew up?
Old Dec 6, 2007 | 12:20 PM
04 Rocko Taco's Avatar
How did you set the timing on the new motor? and who did the EFI install on the 22R? Do you truxt that guy to not have done a crap shod job?
Old Dec 6, 2007 | 12:53 PM
skife's Avatar
timing is set right 5* BTDC at the distributer and the cam timing is right.
i did the EFI install myself, the truck came with EFI so it was just a matter of bolting stuff on
cam timing was set so that the notch on the cam sprocket was pointed stright up while the motor wast at TDC
Old Dec 7, 2007 | 06:52 AM
Georgiadave's Avatar
Without looking at the engine, this is just speculation, but it sounds like your distributor advance is not working. I would check that by looking at the timing marks with a timing light as you give it some throttle. It is easy to misconnect or forget wire and vaccum hoses during an engine install, and that may be the problem.
Godd luck.
Old Dec 7, 2007 | 07:41 AM
skife's Avatar
so if the vaccume lines we're a complete mess (like they are) it would do this?
Old Dec 7, 2007 | 10:06 AM
Maybe. The distributor is not advanced via vaccum, but the ECU is reading vaccum when it commands the distributor to advance.
I would study the vaccum line diagram in the FSM on the sticky and make sure you have everything connected to the proper place.
Old Dec 7, 2007 | 10:57 AM
skife's Avatar
okay, i'll throw it together within the next couple days and hopefully it gets better, thanks guys.
Old Dec 9, 2007 | 09:53 AM
skife's Avatar
problem solved.
22RE is a vacume nightmare.
is it normal for these motor to have alot of top end rattle? like a loud ticking noise
Old Dec 9, 2007 | 10:00 AM
ozziesironmanoffroad's Avatar
yeah, the 22re is a noisy one. and yes it is a vacuum nightmare. especially with the cali ones.
Old Dec 9, 2007 | 11:11 AM
skife's Avatar
loud enough to hear inside the cab with the hood off?
Old Dec 9, 2007 | 11:34 AM
yotasavg's Avatar
yes id say so. my old 22re was LOUD
Old Dec 9, 2007 | 05:36 PM
Glad you got the engine running. You notice I advised study, not read the vaccum diagram, it is a complicated system.
It would not hurt to adjust the valves. The valve train is pretty noisy though.
Old Dec 9, 2007 | 08:48 PM
skife's Avatar
valve lash was set at .010 as per the cam card says.
i'll try to get a video of the sound while i'm replacing the leaky radiator tomorrow
Yont283
Sep 23, 2022 08:06 PM
vasinvictor
Jan 20, 2016 12:39 PM
ibayne
Jun 26, 2015 06:30 AM
infinityisfive
Jun 16, 2015 06:51 PM
2k-c
Jun 26, 2002 04:24 AM
