Let me pick your brain - 22RE
Old Dec 5, 2007 | 04:18 PM
Doc279's Avatar
Last month I blew a head gasket on my 1985 22 RE engine. I pulled the head and found the head cracked in a couple of places. The local machine shop welded the head and machined it back down. New guides and seats with new valve stem seals.
I replaced the head gasket, timing chain set with guides, new oil pump and everything looked good. I did not do anything to the lower block - it has 128,000 miles.
The runner starts good and has good power - but smokes badly at idle. I am not loosing coolant. I did a compression test today and expected to find low compression on one or more cylinders. Nope - all cylinders are 165 - 170
I'm going to attempt to borrow a leak down tester tomorrow. Can I have bad rings and still have compression this good ? No knocking and no loss of power - just smokes - mainly at idle speeds.
Thanks in advance for the input.
Doc
Old Dec 5, 2007 | 05:51 PM
84sr5yoty's Avatar
What color smoke? White, blue, or black?
Old Dec 5, 2007 | 05:56 PM
Doc279's Avatar
The smoke is white
88sasturbotoy
Jan 30, 2026 01:57 PM
young buck
18
Aug 27, 2018 02:40 PM
Backcountry411
Jul 24, 2015 08:06 AM
jake_v
Jul 22, 2015 03:17 PM
KBar
Jul 13, 2015 06:01 PM
