285x75x16R fitment HELP
Old Dec 2, 2007 | 08:29 AM
Belize Off Road Team's Avatar
Exclamation 285x75x16R fitment HELP
i might be getting some tires that size, i need to know, can i use these with out a lift on my 91 Surf? or is 275x75x16R my limit with no lift?
Old Dec 2, 2007 | 09:10 AM
anybody?
Old Dec 2, 2007 | 09:31 AM
jfreisner's Avatar
Probably too wide to fit.
Old Dec 2, 2007 | 09:39 AM
that it? they are coming on wheels already, im doing a swap (wheels and tires), so there will be little rubbing? but i can fit them with out MAJOR rubbing? or do i have to chop somewhere to fit?
Old Dec 2, 2007 | 10:23 AM
jfreisner's Avatar
stock is probably 31x10.50, so 285/75 is a bit wider so it will probably rub on the inner fender
Old Dec 2, 2007 | 11:11 AM
AxleIke's Avatar
Not many folks here can help you, as most don't jump to a 16inch rim. Stick em on, you should be fine.
Depending on back spacing, you should fit okay. Those are basically a 33x11.0 tire, and you can run 33x10.50's on that truck with zero lift.
You will probably need to pound back your pinch weld, but i would bet that would be all. You may need to pound it pretty good.
Good luck, let us know how they look.
Old Dec 2, 2007 | 12:05 PM
i will thank you so much for the info AxleIke, i will find out early this week, i go in tomorrow to find out, i'll be sure to post pics right away!
Old Dec 2, 2007 | 12:26 PM
heres a pic of the vehicle they are coming off of, im parked next to it, that Mitsubishi belongs to a friend of mine who wants to be able to lower the Tbars some in the front and put his wheel arch extensions back on with worrying about rubbing - http://www.cardomain.com/ride/2405186/3
Old Dec 2, 2007 | 12:34 PM
notanymore's Avatar
just curious what does 285/75R16 translate into inches?
Old Dec 2, 2007 | 12:44 PM
Sonofmayhem's Avatar
http://www.discounttire.com/dtcs/infoTireMath.dos
About a 33x11.25
I hope so. I plan to add these on my Classic locks
Old Dec 2, 2007 | 01:41 PM
it depends, check here, accord to here it is 32.8x11.5?! http://www.redrock4x4.com/tech/tire_...&method=metric
Old Dec 2, 2007 | 01:47 PM
Well, if they dont fit, beat the weld, or tub the fire wall.
Old Dec 2, 2007 | 01:52 PM
i will!
Old Dec 2, 2007 | 01:55 PM
AxleIke's Avatar
32.8 is a 33. There are very few tires that actually measure the size they say.
Old Dec 2, 2007 | 01:57 PM
lol, oh well, i'll do what it takes to fit them
kawazx636
Oct 6, 2021 03:03 PM
Ritzy4Runner
10
Jan 14, 2012 07:11 PM
deputydawg
Nov 13, 2006 09:58 PM
DeathCougar
Sep 20, 2006 04:41 PM
DeathCougar
Apr 29, 2006 11:44 AM
