Replaced trans/transfer, now driveshaft too long!
Old Nov 24, 2007 | 09:35 PM
Dave M's Avatar
Hi guys,
I have a 91 ext. cab that was originally a 22re but I swapped in a 92 JDM diesel (2l-te converted to 2l-tII burning veggie oil with a 2-tank system) but is otherwise stock as far as I know.
Anyway, my transmission died on me recently and I replaced it with a trans/transfer that was apparently out of a 91 today. I think it's a W56 or at least my bellhousing bolts too it although it had a one piece top plate for both the transfer and transmission shifters which I've never seen before (foward shift case though). I'm not sure what the tranny I pulled was but it had a breather hose from the transfer block off plate to the transfer shifter top plate meaning it may have been a G series? The problem is that when I bolted my rear driveshaft to the output flange the bolt holes for the center support bearing were about an inch off. I measured a plumb off of the flange to the transfer/tranny joint and compared it to the transfer I just pulled and it measures about an inch longer.
I've never heard of this, I assumed all the cases were the same, and needless to say I'm pretty down I just spent the better part of two days wrenching on this thing, doing all the r&r, rear main, new clutch, the works, looking forward to driving her next week and now this happens.
So, what are my options? I would really, really, really like to not have to pull the trans again. Can you change transfer cases without pulling the tranny? If so that could be an option although, like I said, the old one has a breather hose, the new one doesn't, both are forward shift however. Could I just drill a new hole for my center support bearing, although this probably compresses my driveshaft too much? Different driveshaft? Anyway, thanks for your help!
Dave
Old Nov 24, 2007 | 09:47 PM
DeathCougar's Avatar
all your answers can be found here: http://4x4wire.com/toyota/faq/parts/
and here: http://www.marlincrawler.com/htm/tra...earvschain.htm
and here: http://www.marlincrawler.com/htm/tra...ansmission.htm
One shift plate holding down both shifters is a W56 trans. If your truck originally had a G series (two seperate shifter housings) it had a chain drive case.
Old Nov 24, 2007 | 10:15 PM
Dave M's Avatar
Thanks for the help! Looks like I had a G in there before as I suspected. Does this mean that I could get a driveshaft from a 91 that used a W and be fine? My new case is a gear drive so I'd like to keep it. Can you shift into 4x4 on the fly with a gear drive and will the front driveshaft match up between the two cases?
Hmmm, just realized this is in the wrong forum...
Old Nov 25, 2007 | 09:23 AM
I would think you can just get a W-series driveline, given that all other factors are the same (IE Extra cab, short bed, MT, etc etc.
Old Nov 29, 2007 | 03:54 AM
tiresrus's Avatar
I have had driveshfts shortened before. Never had a problem with vibrations.
I put an 83 4 speed in place of a 5 sped and had to have driveshaft made.
mskalmus
May 28, 2017 07:51 AM
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
