Bondo body repair question??? (PICS)
Old Nov 20, 2007 | 06:57 AM
dirtyXplorer's Avatar
Hello,
Before I bought my 4runner, the previous owner mentioned a fender bender that got repaired on the passenger rear quarter.
The other day I noticed a crack in the body. I am gusseng they just bondoed over the dent and now it has cracked. I want to seal it with something before water gets in there and freezes.
What do you recomend to repair bondo? super glue? silicone?
Thanks!
Old Nov 20, 2007 | 07:11 AM
hamiltonj2w1's Avatar
bondo
I worked at a body shop for about 5 years before I joined the millitary and the bondo should never crack. If the shop doesn't replace the body panel they just pull the dent out and use a thin layer of bondo. Some shady body shops just fill the dent with bondo and call it a day and it ends up being an inch thick. You could put some bondo in there just to seal it off so water won't get back there and rust it out but it will probablly keep cracking. My opinion is to go to a reputable body shop and have them knock all the bondo off and pull the dent out and fix it right.
Old Nov 20, 2007 | 01:00 PM
Thanks, I was worried about that. The previous owner had all the paperwork except from the "fender bender".
From looking at the crack , I cant tell how thick the Bondo is but it defiantly is not just a thin layer.
Old Nov 20, 2007 | 04:29 PM
no problem hope you get it all worked out
Old Nov 20, 2007 | 04:36 PM
ydopen's Avatar
Have some fun sand all the bondo off and start over again. Bondo sand it primer it and paint it.
Old Nov 20, 2007 | 04:53 PM
I could always Rhino Line over it
J/K
Old Nov 20, 2007 | 05:11 PM
ydopen's Avatar
do it have fun with it
Old Nov 20, 2007 | 05:16 PM
yotasavg's Avatar
J/K
i don't know why you're joking about something like that. just do the whole truck.
Old Apr 5, 2013 | 06:27 PM
banoobee17's Avatar
I had a tire blow out drivers front tire and hit under my drivers door and cause this damage. So i was curious if have to bondo it or can i replace this
Old Apr 5, 2013 | 07:30 PM
nothingbetter's Avatar
Thanks for re-using an old thread. Wow, looks like a fair amount of damage. Without being there to look at it I'll give you body work basics.
1. If its bent, fix it. If its kinked, replace it.
2. Your body filler should be no more than a 1/4" thick.
3. The metal work is (arguably) the most important part. Bad metal work and you'll never get it straight and looking good.
From what I can see, and taking a long shot, replacing that section of the rocker is likely your best bet. Depending on the vehicle you can probally get replacement rocker panels for it pretty cheap. Then measure, cut, sleeve, weld, grind, fill, prime, sand, paint, and apply corrosion protection to the inside. But since rock gaurd is easier to apply than paint and will make the final out come look better, do that to both sides instead of painting.
As for the door, try to find one at a wrecker. Or buy a new aftermarket door. I ordered mine through work (a bodyshop) and it came out to about $200 a door. Thats new, aftermarket, no rust, no dents, no old paint to fight with, no rock chips to deal with. Paint it, swap over the guts and your done.
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
mdev126
Oct 4, 2015 04:48 AM
Sep 4, 2015 09:27 AM
A2theK
Jul 12, 2015 10:46 AM
