Anyone found a timing cover & hg oil leak fix?
My '88 22R 4x2 is leaking oil at the top of the timing cover, where it meets the head gasket. I know this is a common place for a small oil leak. I was thinking of putting some RTV over where the oil is coming out, but I doubt it will stick without having any pressure on it once it dries. Other than taking off the timing cover and putting some RTV on there, does anyone know of a quick fix?
This is what usually happens when someone thinks they can change the timing chain without pulling the head... It's almost impossible to keep the front of the head gasket in good enough shape to prevent leaks like this.
If it were me and I didn't want to pull the cover and head, I'd spray the area good with brake cleaner and wipe it up good and try smearing black permatex in the crack as well as I could.
No guarantees though until you strip it all apart and install new gaskets.
Is that GM sealant sold at auto parts stores or will I have to go to the GM dealer? Do you think that would work better than regular grey RTV?
duckhead
170
Nov 13, 2017 06:07 AM
