Rattling noise in drivers side dash. ideas?
Hey all... I took my tacoma on the first long distance drive since I bought it and it developed a rattling sound. We can't pinpoint exactly where it is coming from, but it seems to be in the dash or drivers-side kick-panel. Basically, somewhere to the left and in front of the driver.
It kind of sounds like a speedo cable, but the speedo needle doesn't bounce around at all like I would expect.
Then....
Just last week, I noticed a similar sound coming from the same general area on the passenger side.
In both instances, the sound doesn't start until the truck is going around 45 mph and stops when you slow down much below that.
Do you folks have any ideas what this could be?
Then....
unfortunately it could be several things. try taking the knee bolster down and see if you see anything that could be moving or rattling. Grab things and shake and see if u can replicate the sound. I had a similar issue and it was the harness to my remote start rattling against some stuff.
I think there's a TSB about dash rattles in Tacos and 4Runners. Something about a bracket touching some metal part. I know mine has a rattle on the passenger side, but it's above the airbag and I've never been brave enough to remove it to check it out.
From the .gov website, I don't see anything about it. You can do a search on your own vehicle here:
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
For what it's worth, I get a rattle in my driver door when the window is cranked all the way up. If I just tap the window down button (window is still closed) the rattle goes away. Good luck.
This might sound odd, but put your defrost onto full windshield, and crank teh heat and fan all the way up for a few minutes and see if that helps. My brother was telling me this used to happed to him in his '99 taco. I had/sometimes have something similiar and it helps mine.
i hate to dig up an old thread, but did you ever figure the problem out. or does anyone have any info on the TSB for the dash rattle?
My 03 just started doing this tonight
this is really starting to make me wonder, my 03 with 70k miles has almost as many problems as my 89 honda with 270k on it
Noises/rattles can be tough to find,because the sound bounces all arond the cabin....many moons ago I traced several that would happen more frequently when the outside temp would drop..Most of them comming from the dash area (rattle bouncing off windshield)ended up being loose dash clips...THE ONES THAT LOCATE THE DASH PINS WITH THE FIREWALL...they just need a couple wraps of thin felt/foam tape...Unfortunatly the entire dash needs to be removed..No easy task even for an experienced tech.
Only real short cut to possibly cut down on the noise if the rattle is comming from this area of the dash..is to jam in some foam backer rod along the whole length of where the dash and windshield meet....something like this,maybe 3/8 or 1/4 :
http://www.mountainhomebuildingprodu...G-p-16204.html
As mentioned by others, there are plastic clips that attach the dash cover to the firewall that can rattle. I was able to access mine by removing the gauge cluster and then cinching this area of the cover (left of the cluster) to the firewall with some wire. Worked well for me.
