Big 3 problem at fuse box
How did you guys get the battery to fusible link attached? I can't get either of the 2 screws in the fusebox to come unscrew. I first couldn't budge it, then I hit it w/some PB blaster and let it sit overnight. Now I'm just spinning the nut on the other side. Ideas?
Go into your User CP (control panel , link on top bar of page) and put the year make and model of your truck in your Signature and it will be posted with every message
None that I can tell. The nut is encased by the plastic, meaning I don't believe its supposed to move. Nor is there any space to get a wrench in there. It looks like, to me at least, that you should be able to just unscrew the screws and the nut would stay put. However, because they are torqued down w/like 200ft/lbs, I just started spinning the nut w/in the plastic.
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
