Did I get a bad water pump or is this the Timing Chain
Old Oct 11, 2007 | 05:59 AM
AustinTaco's Avatar
I have a rebuilt 22r with some mods. When I bought the truck, it was overheating, but not bad and I changed everything(thermostat, hoses, coolant, radiator, and finally, the fan clutch). The clutch ended up being the problem. However, on Saturday, I drove a few blocks and when I stopped I heard a rattling noise and I had coolant dripping from near the water pump. It had not gotten hot, so I just went back and bought a new water pump and installed.
After the install, I started it up, let it warm up, and I had no leaks so I went to take it on a test drive. I get a few blocks and I hear the same rattling noise and I have lots of coolant coming down from "near" the water pump area. However, while looking at it, I don't see coolant coming from the water pump at all, or at least not around the gasket, but I couldn't tell where the source of the leak was.
I am afraid the guides to the timing chain may have went and I have a hole in the TC cover, but I can't see it if that's the problem. Any ideas? I searched, but couldn't find a description like mine, so I thought someone on here may have had a similar problem. Thanks!
Old Oct 11, 2007 | 07:43 AM
4Crawler's Avatar
Pump will likely leak out of the weep hole, located on the bottom of the snout where the shaft extends through. Hole in TC cover will allow oil/water mixing, usually not an external leak from what I have heard.
Old Oct 12, 2007 | 05:35 AM
AustinTaco's Avatar
I feel dumb, but this might help out anyone else with the symptoms. It wasn't the water pump after all. When I had the old one out, and I turned it, it didn't make any noise, but it was much more free spinning than the new one, so I thought that was what I was hearing. In reality, the leak was from the heater hose that goes to the back of the water pump(its right above the alternator) and the noise I was hearing is my AC clutch (which has not worked since I bought the truck back)...two unrelated problems that conspired to make me think my water pump blew.
However, I have a new water pump now and it was probably time for a new one.
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
puddlepirate
Jun 30, 2015 05:08 PM
paxanders
Jun 21, 2015 06:29 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
