93-98 T100s All T100 trucks
toyota t100 4wd disk removal
Old Sep 29, 2007 | 09:36 PM
joedirt724356's Avatar
Has any on e out there replaced the brake disks on a 95 4wd toyota xtra cab SR5?
I cant figure out how to get the disk off,I have tried removing every bolt around it and looks like it might need a pull tool, can anyone help out there?
Old Sep 29, 2007 | 09:59 PM
Knuckles's Avatar
you mean rotors? its easy just unbolt the caliber. it only has two bolts.
Old Sep 29, 2007 | 10:02 PM
CJM's Avatar
CJM
You mean the front rotors?
Unbolt caliper and housing, remove hub-it will come right off.
Old Sep 30, 2007 | 08:55 PM
It looks like it should slip off but thay are frozen on.I have removed the calipers and the grease cap and the bolt under it. I guess I could hit it witha hammer but I dnt want to jack anything up.
Old Sep 30, 2007 | 09:00 PM
also the hub wont come off ether
Old Sep 30, 2007 | 09:19 PM
CJM's Avatar
CJM
You unbolted all the bolts around the hub, then removed the cone washers?
http://www.4x4wire.com/toyota/tech/autohub/
If that doesnt work then I am stumped, you gotta remove the hub assembly to get the rotors off period, there is no other way.
Old Sep 30, 2007 | 10:43 PM
OK I will remove the cone washers tomorrow and will post back. I have read a couple of threads on it and I will bet it is it. I missed a good wheelin weekend becouse of this,but I hate paying the shop.
thanks
joe d dirt
Old Oct 3, 2007 | 08:38 PM
Jake97T's Avatar
remove wheel
remove caliper and hang it out of the way,
remove hub assembly, youll need a 54mm socket to remove the entire spindle assembly, from there the hub and rotor will slide off, careful not to drop those bearings in the dirt, 14mm socket to remove rotor from hub...clean/repack bearings while your in there,
little more involved than a Mustang front end where the caliper unbolts and rotor slides off...but not too difficult..
Old Oct 5, 2007 | 06:18 PM
Froggy93's Avatar
pull the calipers off. remove the grease cap. remove bolt and washer under grease cap. remove six nuts and washers that hold hub end cap on. if it won't come off to easily, there are two threaded holes in the end cap that can be used to pull cap off. find the right bolts for the hole and start treading them in. they will hit against another part of the hub and push the cap off. once the cap is off, remove the big nut and washer that secure and preload the bearings. pull rotor and hub assembly off the spindle. let us know how things go and post picture of your hub and rotor if you are havinbg trouble.
Old Apr 9, 2010 | 08:43 PM
groomsey's Avatar
One other thing is that when you go to thread in the two bolts that act like a puller make sure you keep the nuts on those cone nuts bolts. They have to be loose of course but keep them on the bolt so the cone washers don't fly off to parts unknown. They are under a lot of pressure and I have had to find several before I learned that.
zd92655
Mar 6, 2022 12:58 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Iceman4193
Jun 28, 2015 10:30 AM
Eagle564
Jun 23, 2015 11:29 PM
streetuner15
Jun 18, 2015 10:59 PM
