Need 12 volt 10-amp switched wire
Old Sep 27, 2007 | 03:23 AM
Frank's Avatar
Can someone advise a good place to pickup 12 volt (switched), at least 10 amp feed under the hood? It's on a '94 pickup truck.
Thanks!
Old Sep 27, 2007 | 04:21 AM
isaac338's Avatar
grab it from any ignition wire thru a relay. i doubt you'll be pulling 10A from any switched wire without lighting things on fire..
Old Sep 27, 2007 | 04:52 AM
NCSU-4runner's Avatar
Or you could run a relay direct to the battery with a switched power source actuating it. What are you trying to run off this wire, some lights? If you are trying to power anything significant I wouldn't tap it into the existing circuits.
Old Sep 27, 2007 | 05:09 AM
mt_goat's Avatar
Yeah use a 30 amp relay straight off the battery (with about 14-12 gauge wire and a fuse on the + wire very close to the battery) and switch the relay with a factory switched circuit or you can add a toggle switch if you like. The factory wiring on these trucks is already a little under-sized for my liking, I wouldn't add much of anything to it without beefing it up.
Here's some info on wiring a relay:
http://www.painlessperformance.com/w.../1098relay.jpg
http://www.bcae1.com/relays.htm
Old Sep 27, 2007 | 08:28 AM
Frank's Avatar
I'll be driving a couple of contactors and a vacuum pump that draws ~5 amps intermittently. This is for an EV conversion. I've thought about adding a relay but was hoping to latch onto something (maybe for the EFI) that was already pretty beefy.
Old Sep 27, 2007 | 08:37 AM
tc's Avatar
tc
x4 for the relay.
an additional 5A is quite a bit on an already loaded circuit.
Old Sep 27, 2007 | 08:40 AM
mt_goat's Avatar
Yeah I was shocked when I saw how small the wires were going to my old fuel pump. They are much bigger now.
80Truck
Oct 12, 2025 07:25 PM
okamikai
Apr 30, 2018 10:19 PM
TDonkey
Jul 26, 2015 10:14 AM
v_man
Jul 23, 2015 04:01 PM
Johntom240
7
Jul 13, 2015 12:18 AM
