89 3.0 Distributor eating itself
My distributor appears to be eating the pickup coil. See linked photo. Anyone ever seen this happen B4? Causes and remedies? thanks
http://www.putfile.com/pic.php?img=6724456
Thanks All.
To install the distributor with no reference mark, you will have to set the #1 cylinder to TDC. Do not just turn the crank until the timing mark says 0* becaust there is a chance it will be 180* off, meaning that the #1 cylinder is at the top of the exhaust stroke. You want it at the top of the compression stroke. The best way is to pull the valve cover so you can watch the valves and rotate the engine until both valves on the #1 cylinder are closed. Then rotate the engine to get the timing marks to 0*. Install the distributor with the rotor pointing towards the wire that goes to the #1 cylinder. Put everything back together, start the engine and set the timing with a timing light.
Another way to get the #1 cylinder to TDC is to have someone turn the engine while you put your finger over the spark plug hole of the #1 cylinder. You will feel the compression when it gets near TDC. You can set it to 0* using the timing marks at that point.
nonstop
7
Aug 11, 2015 09:26 AM
