Pre 84 Trucks 1st gen pickups
22r blowing oil from valve cover into air intake
Old Sep 21, 2007 | 05:32 PM
mrtejman's Avatar
My valve cover breather is blowing tons of smoke out and my intake assembly is coated in oil. the motor runs strong and has no other problems that I know of. Does anyone know what is causing this?
Old Sep 21, 2007 | 05:42 PM
rowdy235's Avatar
my guess would be valve cover gasket- not to pricey and easy to do- I did mine in less than 15 minutes. See my post in this section for more info.
Old Sep 21, 2007 | 06:55 PM
toy power's Avatar
No. you have a problem with excessive blowby. either your pcv system is clogged or there is just an excessive amount of wear in that motor; pull the pcv valve out of the valve cover while it is running and see what the deal is.
Old Sep 21, 2007 | 10:33 PM
mrtejman's Avatar
Yeah, it has a new gasket I will pull the pcv and check it out. I think it is probably worn though when I bought it the timing chain guide was in the oil pan.
Old Oct 2, 2007 | 09:48 PM
mrtejman's Avatar
a new pcv valve and grommet stopped it.
bigjstang
Jun 2, 2025 03:56 PM
coryc85
Sep 9, 2015 06:24 AM
icentropy
Jul 9, 2015 02:12 PM
skoti89
Jul 8, 2015 12:05 AM
Gamble_STi
Jul 7, 2015 07:54 PM
