Synthetic in Diffs - Will it cause leaking?
New Toyota owner here so please forgive me for all the newbie questions...
I've read that switching to synthetic oil on a high mileage truck could cause some leakage, but does the same hold true for switching to synthetic gear oil in your diffs, transfer case, and tranny?
I've got a 1994 4WD M/T Pickup that's got 178K. I'm sticking to regular oil for the engine, but would like to use synthetic in the above mentioned components. Do I have anything to worry about in doing so? I have no idea what the previous owner was using, or if he even changed those fluids at all...
Any words of warning?
Thanks for all the quick replies!
Sounds like the leaking issue is just if switching to synthetic engine oil then? And even then it seems like a hit or miss issue from what I've read.
I've heard that it gets into the seals and tighter spots where conventional oil doesn't lubricate causing the engine to leak or seap a little. I've never had a problem.
Just more hearsay but I hear it's the detergent qualities of synthetic oil that clean the deposits off the seals and cause them to leak when they are already bad. Of course I switched to Mobile 1 with 198k mi on my 3.4 and have had no leaks. Actually, my cylinder head cover gasket actually seems to be leaking less than it used to. I wouldn't worry about switching to synthetic gear oil one bit.
polo451
13
Nov 20, 2016 07:49 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
Aug 4, 2015 02:08 PM
yourrealdad
Jul 29, 2015 11:08 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
