Are Optima/Odyssey's worth the money?
Anyone who has an Optima or Odyssey battery, do you feel that the battery was worth the $$ you put into it? I'm due for a new battery, as mine I know is lagging right now. I've had it for 3 years, its a Truestart from Toyota!
I do not run a high power stereo system, nor do I run anything else besides a CB and lights. I am getting an air compressor soon though (MV50). Should I just stick to Interstate or something along those lines, or shell out the extra cash for a nice deep cycle?
Co-Founder/Administrator
I ran a red top in the 4Runner for 5+ years or so.
It never let me down.
This was with winching with it, listening to a powerful audio system with the engine off for 30 minutes at a time, it worked great.
Putting in a yellow top as a 2nd battery very soon.
Whats a good battery charger? I've got an old one from what looks to be the 70's. It seems to work decent, but, who knows. I've only used it once.
Well, if you aren't going to want to spend the $$$ on a battery, what would you suggest? I wont be getting a winch for at least 1-2 years due ot the fact I am a full time student.
I have had three optimas and for most people they would be great but for me they just do not have a big enough reserve. This means a quick cycle to dead and quick recharges which they do not like very much.
I am on my first set of two (to give me a 24 volt bank) Odysseys and so far I have been very impressed. They are expensive and heavy but just these two batteries are equivalent to roughly 9 Optima yellow tops and they would weigh considerably more and still be damaged by total discharges and quick recharges. I will let you know if these last the 10 years they were projected to last. If they do, then I will be a believer.
Wow, so you set 2 batteries in parallel to get your 24V... now, what do you run off that? What is the point of having 24V, wouldn't that damage the 12v circuits in the car? Ive taken a circuits class, but, cant remember
The circuit is isolated from the 12 volt system and is dedicated to the two compressors--both 24 volt. Although I may also eventually power a 24 volt winch as well since 24 volt winches have roughly double the power without consuming double the amps of a comparable 12 volt winch.
I purchased an optima yellow top back in February and I love it. Well worth the money. I've ran my stereo and auxillary lights for hours while I'm camping and it starts right up. I also monitor the output of it on my volts gauge, it never dropped below 13.5V during 4.5 hours of using my hellas without the motor running. IMO it was worth the $200
Seems like I picked it up at Target or somewhere for $25 on sale.
And yes, it was 100% worth the money for the battery. When i switched it over you could hear the engine cranck over SO much faster and you can just tell it works better.
Plus i left my lights on one night by mistake and the next day it didn't even blink when i started it up.
I wish someone could show me one un-biased test where the Optima outperformed a competitor at half the price. I don't believe such a document exists. The only thing that says Optima is better is their marketing garb. I do agree that they may handle steep angles better, but for most folks that not an issue and I'm not even sure how much fact there is behind that either. Just remember to look beyond the marketing, you'll see the Optima isn't any different than other batteries that cost 1/3 to 1/2 as much.
