Pre 84 Trucks 1st gen pickups
22r block 20r head
Old Aug 16, 2007 | 12:23 AM
fatmatt473's Avatar
22r block 20r head
what do i need for this swap. i was told to run 22r block-20r pistons for higher compression-20r head, i have 32/36 weber-pacesetter header-k&n filter setup ?????????????? i need a bit of help
Old Aug 17, 2007 | 03:36 PM
slacker's Avatar
when I did mine .. I just bolted on the 20R head .. I also did a header , cam , and webber 36DPI or S ? cant remember , anyway , it was the mechanical large bore webber . I used an adpter to mate it to the original air cleaner , k&n inside worked well . double chain .. and a few other goddies .. ~150 hp .. worked well for a long time .
Old Aug 17, 2007 | 04:06 PM
Kaleb's Avatar
20R Pistons will fit a 22R block? So the pistons would have to be over sized? If so then why not just run high compression 22R pistons?
cars-guy
Aug 16, 2020 06:59 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
calderp
Jul 27, 2015 09:58 AM
87blyota
Jul 10, 2015 04:31 AM
