speedo lags and my car won't go faster than 120 kph
i'm having a little trouble with my 4runner
I juts got my alternator changed and it was driving fine. After about a day, it started to act up. I started to notice that my speedo would lag when i'd accelerate.
i'd be going 30 kph already but it'd be stuck at zero. After maybe half a second it would catch up.
if i let go of the gas, the speedo would hover at whatever speed i was going and after a while ( like 30 seconds ) it would fall on it's own. If i press the break it would fall faster.
at 100 kph i'm reving at 2k RPM. trying to maintain the speed feels like i'm constant accelerating and it feels like it's pushing really hard.
at 120 kph i am always on the gas trying to maintain the speed. it's at 2.5K RPM and it will not go higher than that.
I recently had a misfire late last year, ended up being a bad sparkplug, but i don't hear the engine skip, or anything this time. It's fine for acceleration at low speeds, but the speedo lags. The tach is fine, it's very responsive.
Any help would be grateful!
right now i'm going to try and reset the ECU, i'm going to let the battery sit for about 10 minutes unpluged from the car. and then let it idle for about 20 minutes. This should reset the AF ratio and whatever the car needs to reset and adjust.
Sounds like you are overloading the new alternator to me. Was it new or rebuilt?
It sounds like you are not getting a good burn and that can be from not enough power. I would have your alternator tested.
montanatruck
Feb 26, 2017 07:07 AM
94ofCanada
Aug 14, 2015 06:37 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
