Coolant squirting out the radiator on start up
Old Aug 10, 2007 | 10:33 PM
kayakken's Avatar
Cool Coolant squirting out the radiator on start up
I have coolant squerting out of my radiator on startup
like the compresion of the engine is pushing it out but thire is no water in the oil or on the spark plugs
blown head gasket?
good comperession on all cyclinders
I dont know
Ken
Old Aug 12, 2007 | 02:27 PM
klr toy's Avatar
change your head gasket, soon! Compression pressure is much higher than the cooling system. It may go one way but not the other. It's only a matter of time before coolant will fill your cylinders. I've seen this 4 times now. It usually happens with jobber head gaskets at around 25000 miles after a rebuild or replacing a gasket in my experience. It's also usually cyl# 4 that hydraulics first. I recommend using a new gasket from Toyota only. There is a difference! I happen to be doing one today with the same problem.
Old Aug 12, 2007 | 03:01 PM
kayakken's Avatar
thx dude I allready figgerd that but wanted conformation
its sitting wating for me to work on it
I have a day off soon so I'll rip into it then
Ken
Old Aug 31, 2007 | 10:45 AM
kayakken's Avatar
HG changed and up and running better than ever (thx to other tweeks and parts)
thx for the tips that I have read on this site
Ken
Old Aug 31, 2007 | 05:02 PM
fustercluck's Avatar
Late to the party, glad you got it resolved.....
Old Mar 15, 2010 | 07:44 PM
kayakken's Avatar
Up date: I changed my hg again and head but water still gushing out of my radiator so ??? cracked block?
new engine and keep theses parts for re-build after I find a good block
Ken
Old Mar 15, 2010 | 07:49 PM
peow130's Avatar
If water is gushing out of your radiator, maybe you need a new radiator cap?
take the T-stat out and see if that helps, it might be stuck closed
Old Mar 15, 2010 | 08:48 PM
mightymouse's Avatar
Dude if water is coming out of the radiator then why did you replace the head gasket? Was it leaking out of the head gasket? Did you do a compression test to see if the head gasket was indeed the culprit? If the radiator is obviously the problem with coolant squirting out and all wouldn't you think the radiator would be the first thing to address? Where is the coolant coming from on the radiator? cap? seem? fins? hoses? Maybe i missed some thing but why did you replace the head gasket in hopes it would fix the leaking radiator? As your water pump turns when you crank the motor upon start up it moves coolant through the passages in you block and hoses so with each crank the coolant should or will be forced through your hole aka leak. Good luck man but the problem just might be squirting you in the face.
Old Mar 16, 2010 | 09:12 PM
kayakken's Avatar
Cool
the radiator is new as is the thermastat.
differant head
I thought I might have bunged the HG job when I did it the first time
the water is coming out the filler neck where you put the cap like a gyeser
waa hoo old face full and isn't hot
Its on start up I should have typed that erlyer
I think I cracked the block
found a 22r on that CL place
so now comes the rip and build
take parts off that engine and put on this one
its out of a 84 4X4 so it will fit right in NP
now I get to clean and paint my engine compartment and front diff
fun fun good thing I got a power washer
Type back soon with pics
Ken
Old Mar 17, 2010 | 07:03 AM
laskt9's Avatar
did you try a new radiator cap?
Old Mar 17, 2010 | 08:20 AM
tj884Rdlx's Avatar
if you're starting cold, you should get no gushing. the t-stat should be closed and the coolant in the radiator shouldn't even be in the circuit.
once the t-stat opens, you get flow to the rad from the top hose, and out to the pump thru the bottom hose.
so i'd want to know if the radiator was flowing freely, and then i'd want to know why the t-stat was open right from start up.
good luck man.
http://ncttora.com/fsm/1990-1995_4Rn...s/operatio.pdf
Old Mar 17, 2010 | 11:55 AM
kayakken's Avatar
thanks for the help
I still think I cracked the block
As far as the rad cap why would that be the problem if I dont have it on and water is pumping out of the rad
could be the head but I changed the head the problem is still there
and the T-stat is being pushed open by the water presure
thx for the help
pics
engine in truck
and repair manule he tossed in for $5.00
look donor engine $100 gota love craigslist
happy yotaing
Ken
Attached Thumbnails Coolant squirting out the radiator on start up-img_6791.jpg   Coolant squirting out the radiator on start up-img_6794.jpg   Coolant squirting out the radiator on start up-img_6787.jpg
Old Mar 17, 2010 | 06:25 PM
laskt9's Avatar
oh lol fail on my part my bad
Old Mar 17, 2010 | 07:00 PM
kayakken's Avatar
more pics from todays work
I got the engine redy to pull
and looked over the new one I dont think it will be a problem at all
pic 1
taking the distbueter out
pic 2
nice paint
pic 3
dont forget to put your bolts and nuts back whenever you can
Ken
Attached Thumbnails Coolant squirting out the radiator on start up-img_6796.jpg   Coolant squirting out the radiator on start up-img_6802.jpg   Coolant squirting out the radiator on start up-img_6813.jpg
Old Mar 19, 2010 | 10:06 PM
kayakken's Avatar
well.... here is some pics
the gasket was messed up
the block & head showed signs of leaking between 1 & 2
block seems fine head 2 warped
I just put this in and fired it up and it blew the gasket
Oh well differant motor goes in next
I am going to gasket kit it tomrow
Attached Thumbnails Coolant squirting out the radiator on start up-img_6838.jpg   Coolant squirting out the radiator on start up-img_6839.jpg
Old Mar 19, 2010 | 10:12 PM
kayakken's Avatar
Btw
I had to get a universal from the naibor to get the bell housing bolts
I want my stubby rachet I cant find in my shop
I gotta clean this place up
ken
Attached Thumbnails Coolant squirting out the radiator on start up-img_6824.jpg
Old Mar 21, 2010 | 09:02 PM
kayakken's Avatar
its all together
had some minor problems
like #1 piston was lose in the wrist pin so #1 out of the old engine in to the new
but other than that it went like butter
if any body knows how that gasket could blown after only running for a few minuets
let me know
but new engine goes in tomrow
Ken
Attached Thumbnails Coolant squirting out the radiator on start up-img_6842.jpg   Coolant squirting out the radiator on start up-img_6844.jpg
Old Mar 23, 2010 | 10:14 PM
kayakken's Avatar
FrankenYota lives
It is ALIVE ..IT IS ALIVE
But serously boy it runs sweet and looks nice
thanks for all the help I got from the ppl on here
Ken
Old Mar 25, 2010 | 12:14 PM
tj884Rdlx's Avatar
glad to hear you're rollin' again!
Colington
Mar 8, 2020 09:51 AM
Road Bull
Oct 10, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
raiderhawks00
Jul 8, 2015 06:23 PM
karbin
Jul 5, 2015 11:37 PM
