pinion seal,overtightened nut
if i overtightened the big nut ,does it mean that the new seal is no longer good?it was crushed in a little to prevent slipping,and thats where i tightened it back to.its still leaking.well i read that its 19 lb.torque,what is that snug?
Yeah, the pinion nut typically is tightened to roughly 80 ft-lb when using a crush sleeve, or 150-200 ft-lb when using a solid spacer. If a new seal leaks after you install it, it may be due to faulty installation (spring on back side of seal might have fallen off when seal was tapped in), there could be wear on the pinion shaft where the seal rides causing the leak, your pinion bearings could be loose/worn, causing the pinion to wobble slightly, etc...
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
Sep 5, 2015 06:52 PM
