22re timing chain tensioner
Old Jul 18, 2007 | 07:01 PM
smackay's Avatar
Last August I had the timing chain on my '92 4runner replaced at about 202k miles. Lately, I notice a brief rattle when I start the engine after it has been shut off for a while - e.g., in the morning when it has sat overnight and when partly warm after sitting for an hour or more. The rattle lasts about 1 second. I had the valve cover off on the 4th to adjust the valves: chain and guides look good, like new. The engine now has 214k miles and runs great otherwise. I am wondering if the tensioner is behind this brief rattle: should I replace it? Any advice is appreciated.
Old Jul 18, 2007 | 07:04 PM
DudeBud's Avatar
what oil filter are you using?
Old Jul 18, 2007 | 07:36 PM
smackay's Avatar
I use Toyota filters bought from the dealer.
Old Jul 19, 2007 | 06:03 AM
Flash319's Avatar
That is normal. It takes a second for the oil to push the tensioner.
Old Jul 19, 2007 | 06:19 AM
4Hummer's Avatar
Hope you didn't over torque the bolts
Old Jul 19, 2007 | 06:38 AM
DeathCougar's Avatar
That generally happens when you A. Over torque the bolts, or B. use an aftermarket tensioner. I learned the hard way not to do either.
Old Jul 19, 2007 | 10:34 AM
DaveInDenver's Avatar
This is exactly right. The first is just taking your time and the second you just need to be careful of the parts. You can use non-OEM tensioners if you know that they are good quality (Japanese made, for example, is one thing to look for). I figured this out the hard way, too... I just rebuilt my engine this winter and it doesn't rattle on start-up at all. Before the timing chain failure it did rattle similar to a diesel at start-up.
Old Jul 19, 2007 | 06:40 PM
smackay's Avatar
My mechanic didn't replace the tensioner. I will ask him about the torque issue, and will check maintenance records supplied by the former owner to see if the tensioner was replaced when the original chain was replaced, about 100k miles ago.
Old Apr 14, 2008 | 01:56 PM
mtrdrms's Avatar
Reviving an old one here but does anyone know the torque so I dont overtighten it?
Andy
Old Apr 14, 2008 | 02:15 PM
thook's Avatar
Enggg.....a reused tensioner.
This is how one looks after the second time around.
Old Apr 14, 2008 | 04:15 PM
My99's Avatar
What torque specs are you guys referring to BTW? Torque on the timing chain guides? tensioner?
Old Apr 14, 2008 | 05:04 PM
thook's Avatar
The tensioner bolts.......@14ft/lbs.
(Silly me....didn't notice the origin date of this thread)
Old Nov 1, 2011 | 12:40 PM
jeetS's Avatar
Thread resurrection:
My truck does the same thing, except it has a new Toyota tensioner and I torqued the bolts to 14ft/lbs...
Toyota filters... It consistently does it, have done multiple oil changes...t-chain was done about 8k ago...
Any other ideas?
steve miller
Oct 10, 2015 01:40 AM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
