Pre 84 Trucks 1st gen pickups
80 Pickup Hi-Steer ?
Old Jun 29, 2007 | 09:04 PM
corvettelvr73's Avatar
A buddy of mine has a 80 pickup 4x4 and was woudering if you could put hi-steer on if you dont lift it I told himm you can but do you have to have a lift or not. If you do how much lift do you need.
Old Jun 29, 2007 | 09:36 PM
DeathCougar's Avatar
you will need 4" lift methinks. Why put hysteer on a non-lifted truck? If you are not wheeling it, the stock steering is fine.
Old Jun 29, 2007 | 09:44 PM
He has his motor out and thought it would be easyer to do it plus his had hi steer sitting around for a long time so he thought he should go ahead and do it. He does wheel it also alot. and dont want to lift it right now because of money.
Old Jun 30, 2007 | 09:24 AM
4Crawler's Avatar
You'll need about 3" of lift to have the draglink clear the frame and springs. Might be able to get by with less lift if you notch the frame for the draglink. I had ~3"-3.5" of lift on my '85 and was able to squeeze crossover steering in there, but it took some work to adjust the draglink height to clear the frame. It would just rub on the springs with the passenger side at full droop.
Old Jul 1, 2007 | 06:32 AM
Yota Tony's Avatar
I think you could do it with no lift if the springs/axle were moved forward. However if your still on stock suspension, steering and smaller tires...I wouldn't bother.
Old Jul 5, 2007 | 09:21 PM
dropzone's Avatar
Fossilized
Don't forget the IFS steering box and mount kit that is necessary. What kind of High steer is it? I am in the market for one if he doesn't really need it.
Old Jul 6, 2007 | 03:19 AM
waskillywabbit's Avatar
X2
sandyota
Feb 4, 2021 11:16 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
rondogracing
Jul 14, 2015 07:00 PM
