General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Simple Wiring Question, please
Old May 21, 2007 | 03:52 PM
HaveBlue's Avatar
Front and rear parking lamps are out as a result of a fuse blowing. Every subsequent fuse has blown immediately. I know this is a short. My question is - could a broken ground wire cause the short? If there is no ground, will it pop a fuse?
Old May 21, 2007 | 05:02 PM
dibble9012's Avatar
If your bulbs are dual filiment, I think it's possible that the bulb shorts out internally?
It won't blow a fuse if there is no ground wire.
Possibly a bad relay, maybe?
Old May 21, 2007 | 07:14 PM
4Crawler's Avatar
Try simplifying things, pull all the bulbs and re-test the fuse. Could be a bulb in which the filament shorted internally (it has happened before).
Also, did you do any wiring mods lately, such as a new radio, amp, etc. or a trailer wiring harness? If so, check all those things and/or disconnect those parts and re-test.
Old May 22, 2007 | 12:13 AM
amusement's Avatar
Call me stupid but there's been a rash of electrical problems in Yota's reported on the board. In my mind it's time for relay spring cleaning.
Old May 22, 2007 | 06:20 AM
HaveBlue's Avatar
That's just it - I haven't touched any of the wiring lately except to install a new CB antenna. And I didn't touch any wires for that.
The internal short on a bulb is a good idea. I'll try that tonight.
THANKS FOR ALL THE SUGGESTIONS!!!
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
