2in body lift and arb bumper
Old May 20, 2007 | 01:27 PM
Firefightertaco's Avatar
Does anyone know if they make brackets for a 2in body lift so a arb will fit right, or has anyone fabed there own up?
Old May 20, 2007 | 01:39 PM
d0ubledown's Avatar
afaik, assuming youre getting the tacoma one, there is no body lift modded brackets available. my prado one however has enough adjustment in the mounting holes to accomodate my 1.5" body lift as its got a different mounting system. youre probably looking at having to have your mounts modded to fit the 2" gap...
Old May 20, 2007 | 01:53 PM
Jdizzydub's Avatar
I'm not sure of the ARB mounts, but like said above the PRAdo can slightly accomadate..I think there are a few guys runnin 2in BL with their ARB. I have a 2inBL and I ordered the bumper relocation brackets to lift my stock bumper---not sure if these will work too, but it gives ya an Idea. Good luck
Old May 22, 2007 | 12:50 PM
harpen123's Avatar
looks like time to take the stick welder and trying some stuff. I can send u pics of mine if u need them.
Old May 25, 2007 | 10:32 AM
4Crawler's Avatar
See:
- http://www.4crawler.com/4x4/ForSale/...ets/index.html
Final step is to fully weld the bracket back together and add gusseting to the back side of the extended tabs. The picture above was only a test fit and then the owner decided to keep the brackets stock.
Old May 25, 2007 | 10:51 AM
snap-on's Avatar
on my truck the ARB bar wraps around the front sub frame, so the bottom of that C will need to be cut off, as well as the intrigal 1/4" plate "brackets" that hang down and catch the bottom of the frame rails will have to be cut off and extended (or not used)
Old May 25, 2007 | 10:53 AM
4Crawler's Avatar
The different bumpers for the different generation trucks have different bracket setups. So the modifications needed will vary with the design of the bumper and bracket. Other option is to leave the bumper where it is or to raise it less than the lift. Here is a 3rd gen pickup w/ 1" body lift and stock bumper mount:
So for a 2" lift, if the brackets allowed say 1"-1.5" of adjustment, raise the bumper that high and call it good.
Old May 25, 2007 | 09:16 PM
harpen123's Avatar
got mine as high up as it will go already but I was wondering if I could get a ballpark on price
Old May 26, 2007 | 07:06 AM
4Crawler's Avatar
Probably would run 1-2 hours of shop time to modify the bumper brackets, so whatever the going rates are in your area, go from there.
Jun 1, 2021 01:51 PM
nick9455649
Sep 11, 2015 05:10 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Cabell
Jul 24, 2015 12:14 PM
