Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Bazooka Tube Install Help
Old May 17, 2007 | 03:09 PM
Swissdrums's Avatar
So i got a Bazooka Tube 8" from a friend for free!
All i got was the tube...what else do i need to hook it up?
Thanks
Old May 17, 2007 | 03:10 PM
Elton's Avatar
8ga amp wiring kit http://www.knukonceptz.com/productDe...?prodID=eKo-K8
Old May 18, 2007 | 07:42 AM
OSIRIS's Avatar
Where are you? Probly in Fairfax. I'm in C-ville, more central VA.
Do those things have an internal amp or are they just the tubes?
If it has an amp, then basically what he (Elton) said. If not, get an amp also.
This is what I used. You should get it by Monday if you order it today or you can find this at any stereo shop around your town. It is all you need and should be around $40 or less.
http://www.crutchfield.com/S-jrjx876...g=711&I=142PA8
Old May 18, 2007 | 11:26 AM
Tron's Avatar
some have amps and some don't. If i does have an amp you need the wire plug that plugs into the amp or you will be SOL.
Old May 18, 2007 | 12:48 PM
OSIRIS's Avatar
Do you mean the RCA cables?
If so that is included in both of our replies, if not, what wire plug are you talking about?
No hijacking. just posting the question that might be asked later for everybody else.
Old May 18, 2007 | 03:10 PM
TXST8tj's Avatar
the amplified Bazooka tubes come with a wiring harness that plugs into the back of the tube to connect everything up...12v power, ground, remote, and RCAs or low level line input. use RCAs if you have an aftermarket h/u. use the low line if you have a stock h/u.
the passive (non-powered) Bazooka tubes will only have binding posts to connect the speaker wire from an external amp.
so basically, if it's an amplified unit, you will need the Bazooka wiring harness and an amp wiring kit.
if it is a passive tube, you will need an external amplifier, and amp wiring kit.
for something like a Bazooka tube, don't get carried away on the amp install kit. go to walmart and buy the $17 Scosche 8 gauge amplifier install kit. it will have everything you need to hook up the tube. i am all about high quality stuff, but for a Bazooka tube, that is all you will ever need.....and don't get me wrong, that's actually not bad stuff at all. wiring is way overpriced in general. don't get caught up in the hype.
Old May 26, 2007 | 05:35 PM
dijlop's Avatar
true that. i used the walmart junk to get my system up and runnin. and im a little better off than a zooka tube. lol. dont rly like the tubes much.
Blamalam
Mar 12, 2022 07:34 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
priest16
15
Aug 6, 2015 07:43 AM
adammtb
Jul 27, 2015 11:57 AM
DrZero
18
Jul 24, 2015 11:31 PM
