Sponsored by: CARiD
Sticking Throttle After Weber Carb Install
Old May 15, 2007 | 08:28 PM
orangepartyhat's Avatar
Long time lurker, first time poster. I searched and read about 15 pages regarding similar problems but couldn't find anything that helped so I thought I would post this...I have a 82 pickup with a 22r, I installed a new weber carb and the engine runs great but I'm having one problem... my throttle sticks. Whenever I push the gas pedal and let off the RPMs stay the same, it doesn't come back to idle. If I rev the motor from the carburetor it works perfectly. I've tried moving the position of the pin in several different holes in the throttle plate (I guess that's what it's called) and adjusting the tension on the throttle cable every way I can think of. I went back to the instructions that came with the kit and verified that I installed the linkage adapter correctly on the valve cover, I'm totally stumped. Any advice would be great!
Thanks,
Chad
Old May 16, 2007 | 11:32 AM
surf4runner's Avatar
replace and/or add a stronger retrun spring
Old Dec 14, 2007 | 01:57 PM
lenwood's Avatar
i have a 32/36, had to put a stiff return spring on and cured the problem immediately
Old Aug 10, 2019 | 09:35 PM
Koby Dumas's Avatar
Where do you get one of those Springs I just put a new one on mine as well and it will not return
kazuya2416
Apr 5, 2024 02:17 AM
dumpster84
Apr 30, 2016 06:03 AM
Yota.Jay
Jul 23, 2015 08:08 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
