Pre 84 Trucks 1st gen pickups
questions about 5'' lift and driveshafts.
Old Mar 25, 2007 | 07:13 PM
Hayes's Avatar
Looking at buying a 79 pickup. It's in great shape and already has 4.88 gears.
My question is this. I have enough money to get the trail-gear.com 5'' lift, 35 tires, wheels to go with them, t-case gears, the IFS box and mount for the hy-steer right away. When I lift it 5'' I assume I need to get longer driveshafts. My question is how long do they need to be and do I need to relocate the mounting points on the axles to adjust for the lifting angles?
Thanks in advance for the info,
Brandon
Old Mar 25, 2007 | 07:25 PM
paxil4x4's Avatar
Drama Queen/Banned
My advice, buy a lift kit from someone else other than trailgear.
Old Mar 25, 2007 | 07:30 PM
usmarinerecon's Avatar
Obviously this guy knows nothing about lifts.... Trailgear is a great lift and company. But you should take abvice form someone who actually has lifted there 4x4...
Ask Brian from wabfab.com, he sales them
Old Mar 25, 2007 | 07:54 PM
paxil4x4's Avatar
Drama Queen/Banned
Ok tough guy, go do your research on pirate and marlin crawler forums. Trailgear makes nice parts, but their ethics leave a lot to be desired.
Old Mar 25, 2007 | 07:59 PM
Steve97TJ's Avatar
I would personally look into either Allpro or marlin. Those are both two very well trusted and big name companies. And Marlin and bigmike both stand behind there products.
Old Mar 27, 2007 | 01:48 AM
skoaq's Avatar
i second that
Old Mar 27, 2007 | 06:38 AM
4Crawler's Avatar
Brandon
Install lift, then measure for the shafts and go from there. Rear may be OK, but up front, likely will need to be lengthened and also need a longer slip yoke on it as well. Measure flange-flange, ideally with suspension fully compressed and fully extended to get an idea on how long that shaft needs to be and how much slip length it needs. And on the angles, again measure and see:
http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
Old Mar 27, 2007 | 06:48 AM
Yota Tony's Avatar
Up front you can make a square tube driveshaft for cheap. The rear may be good as 4Crawler said.
You'll have to wait and see till the truck is lifted to see what the measurements are like.
Personally I'd go with Marlin's lift over anyone else.
Old Mar 27, 2007 | 10:48 AM
jriebe's Avatar
Advice from Pirate4x4 is about as useless as tits on a boar. The people that do take the time to post on that forum are generally on the hunt to flame someone for a silly question vice giving actual advice. And why would Marlin be positive about products from a company who competes with them?
Yeah, his response could have been more professional but damn...just buy the stuff that works for you.
as to the dshafts, lift then measure like several people have already said.
If you don't pan on going more than like 5-10mph in 4wd you could fab up a front dshaft, the rear might be alright, again like several people already mentioned.
And in my opinion, you could just as easily build your own lift...missing links or longer springs, whatever, come up with something creative. Obviously if you don't have the time, money, material to accomplish this then your best bet is to do your research and buy the product that fits your "desire."
Hope this helps,
Jon
Old Mar 27, 2007 | 02:06 PM
Hayes's Avatar
Hope this helps,
Jon
I don't have the time or desire to redesign the perverbial wheel. I can get a kit for approximately the same amount of money that the time to design my own would be worth. They have spent lots of time and money researching so that I don't have to.
Thank you all for the advice on driveshafts and I will probably go for a square ds up front.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
