Timing/ignition issue
Old Mar 25, 2007 | 06:33 AM
alkalineall's Avatar
Hello all. I having a very frustrating problem with my ignition/timing, and wondered if anyone has any suggestions. The first thing is this, to even drive my truck (86 22re 4runner) I have to advance my timing almost all the way. If I set the timing a 5 btdc its almost impossible to make it out of second. I have done extensive work on this truck in the past few months, including two head gaskets (separate motors) and three engine removals/re-installations. I had a similar problem on the last motor and it was partially corrected by replacing my distributor. My logic was that a weak spark could be compensated for by advancing the timing (less cylinder pressure at the time of spark). If anyone has any ideas they would be appreciated. Thanks.
Old Mar 25, 2007 | 09:06 AM
SoCal4Running's Avatar
Distributor could be off a tooth or TPS gets my vote.
Old Mar 25, 2007 | 11:07 AM
jriebe's Avatar
x2....
Jon
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Aug 19, 2015 02:15 PM
rjtrials
Aug 6, 2015 07:25 PM
