difficult steering?????
Hi New to the site. Had a question about my steering??? Not all the time but someitmes its very hard to turn??? feels like no power steering?? doesnt make any unusual noises but just very hard to turn??? My truck is a 95 with 118,000 miles. Real good shape otherwise. Any suggestions? Thanks
Not trying to be a SA, but checked the fluid level? Air in the system from low levels.
Do you have an aftermarket steering stabilizer? I can twirl the wheel on my 92 faster than my Rancho unit wants to sometimes. Feels like a lack of power boost......
Hey! Yeah I did check the fluid level first...steering did it again this morning on the way to work.Its like there is no power steering when i am at a stand still???? it moves in a jerking motion when i do come on to it??? WTF????
How old is the power steering fluid? Is it dark? Maybe you need to flush the power steering system. It's not hard, and if it's not been done in a long time it couldn't hurt.
belts are not old or worn...dont know about how dark the fluid was???? i checked it when it was really cold out and only looked to see if it was up?? i will check for color today....how do u flush the steering fluid??? that might work.....thanks
This may be a dumb question...Are you in 4WD when you are trying to turn? This will cause it to shudder at low speed when turning, especially at low speeds (and on dry pavement)...sorry, had to ask.
Only thing I can think of is the PS bypass valve, but that's if the pressure gets too high and would more likely be at higher speeds, unless it's sticking a little and loosing all it's pressure at idle and picks up again at increased RPM's.
You say at idle sitting still it doesn't work, what if sitting still you rev up, does it work then?
I have tried that thinking it was because of low idle and I have revved it up but i still get the strong arm steering.the wheel jerks as i turn it like something was sticking?????
The symptoms you describe also remind me when I built mine and had air in it. Hard at first, then jerked.
Thanks for all the info....now that the weathers turned I will get under her and fix this. I only got the truck last Dec. from the states and havent had a reall opportuntiy to get at her. Thanks!!
Well with the warmer weather i had the opportunity to dive in. I checked the belt deflection and noticed that the belt was a little loose....tightened it up and behold......works perfect now!!! feel a little stupid as I checked it when it was cold but not close enough...... thanks for all the help though!!!!
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
