Plowed through mud, now my A/C compressor squeels when A/C turned on
Did a lot of playing in the mud over the weekend. Usually I avoid mud because it's such a mess to clean afterwards, but I caved to the peer pressure
I've carefully cleaned the easily accessible portions of the engine bay and hosed down the belts pretty extensively, but I'm still getting a LOUD squeal when I engage my air conditioning. Sounds like when you hear a car with a squeeky accessory belt under the hood, but it's only when I turn the A/C on. Any suggestions? Are any of the A/C parts able to be pulled and disassembled for cleaning, without purging freon into the atmosphere or incurring costly repairs at the dealership?
yeah! clean it up good after ever time you go stump jumpin. i know people like to ride around with sh$t all over their truck bc they think it looks cool but intern its f'ing up your ride.
I actually cleaned up the 4Runner as soon as possible, but bear in mind, I had about a 60-mi journey home before I could break out the hose. I guess now is a good time to mention that I must've also caught some small debris / pebbles in the front caliper and there was a horrific grinding sound coming from the front wheels when I was in the mud, until I put it in reverse and apparently loosened whatever was caught in there. Oh, and now my FIAMM horns work at about 10% loudness vs. before the wheeling trip. Nice. Can I just say that going balls out through mud is a mistake I'll never make again...? What a mess, what a hassle...
Help, I have tried carefully spraying down the belts with water while the engine was running and after the water was spun off, the belts started to squeek again. This is a high-pitched whine and it only occurs when the A/C is turned on. And it is intermittent. It's an ear-piercing sound - my eardrums were ringing after it went off right as I was leaning over the front grill and looking in! Do I need to take the drive belts off and start poking around in there? Please advise.
UPDATE: took vehicle to dealership to fix
Was told there was still mud and debris around the compressor and that the A/C belt was no longer centered on the pulley. Approx $80 to clean it out and re-install the belt. GRRRRR...could've and should've done this myself.
Yes, lesson learned. And yes it's fixed now. A/C turns on like a charm with no belt squeal. 4Runner also ended up needing an alignment as my specs were thrown way off after bumping and bouncing through that mud. I hit some hard bumps and I'm not surprised the front end was out of whack. $159 service bill today...ouch!
skoti89
Jul 8, 2015 12:05 AM
