Install Warn Manual Locking Hubs, 91 4Runner SR5, Auto Tran
I am considering installing manual locking hubs on my 91 4runner. I use the 4WD very little. Will the hubs reduce ware on the front drive train and maybe improve fuel milage?
reduce wear...yes. improved fuel mileage? some say yes, others say no. i'd do it just because you can. go with the OEM asins though, and not the warns. you should be able to find a decent used set from the junkers or from wabfab for $50-100. its a quick half hour/side swap...
Don't know if SW is a good choice or not, but for what I needed them for will be fine, a temp fix until I can remove and inspect front CV's and front drive shaft. Don't do any 4 wheeling much, but do engage every now and then to lube everything up now and again.
I checked out the Wabbit's and if $$$ wasn't tight, I would have got his. I may still later on, but his are the best I've seen and ready to go to boot. If you are going to spring for Warn, go with Aisin
to find a swap out article online, bunches of them and even some in the tech write-ups here on Yotatech.
I didn't see any mileage increase even though the truck feels like it is rolling easier...
As for Warn vs. Aisin ... the Warns will break easier, but that's not necessarily a bad thing. As noted above, it's about a 1/2 hr per side (actually quicker with the Warns since they don't use cone washers) to swap them, which is a whole lot quicker than a CV or ring and pinion...
I still find it funny people say warns break easier. The cheap ones and the superwinch hubs break easy, the premium warn hubs havent failed me yet, nor have the failed a few friends of mine who dont drive yotas.
I have a set of Aisin for sale. 41K on the truck they were pulled from. They are complete with the toyota FSM instructions. I am also going to get all the gaskets from toyota tomorrow to sweeten the deal. $100 + shipping.
I broke a set of Warn Premiums on my landcruiser
Do it! Go Toyota OEM..Aisin
An Excellent Idea! For many reasons. I liked the fact that I could have 2wd low range. Wierd I know! I had to change the CV joints and did not want to do it again. I saw a small mileage increase, but it definately rolls better. With the wheel/tire off the ground, spin the wheel. Then lock the hub and spin it again, huge difference. Be sure to lock the hubs and drive to relube everthing (just as JEBSR5 stated earlier) every now and then.
I held out and searched ebay for the Aisin stockers. I am glad that I did. Strong, Cheap and Toyota OEM. When I got them I tore them apart and relubed and sealed everything. 3 years and not a problem.
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
