Ball Joints
Old Aug 5, 2002 | 01:39 PM
williemon's Avatar
Ball Joints
I need to replace Ball joints on the 90 4 Runner. Any special tools needed? I have a "pickle fork" already. Anybody with instructions? I was told it needs uppers, but I might need to do uppers and lowers.
Old Aug 6, 2002 | 01:30 PM
williemon's Avatar
Anybody???
Old Aug 7, 2002 | 12:31 PM
williemon's Avatar
Anybody at all?? Come on now!! Sombody has to have done this before. How about it....Yoda.....Corey......anybody???
Old Aug 8, 2002 | 10:01 AM
paddlenbike's Avatar
Ball joints hate me and I hate them.
A ball joint separater is an easy way to remove a ball joint. Consider yourself forewarned though that it will likely tear the rubber boot.
Use could also use a ball joint puller that looks something like a harmonic balancer puller.
I want one of these:
$25.99 from Harbor Freight.
All I can say is good luck!
Ken
Old Aug 8, 2002 | 10:28 AM
Corey's Avatar
Co-Founder/Administrator
Sorry williemon, never tackled that before.
I thought for sure Paul or Master Yoda may have.
Corey
Old Aug 8, 2002 | 10:31 AM
williemon's Avatar
Anybody know if the replacements from the auto store are pre greased, or do I need to zerk them and install some grease? Also, if I do grease them, should I use a synthetic grease that I already have, or use a convintional grease?
Old May 19, 2003 | 12:01 PM
I need to replace my ball joint boots. Any advise out there? Any links?
Thanks
Old May 19, 2003 | 07:57 PM
Firefyter-Emt's Avatar
Very easy job... The ball joints bolt in to the control arm, and you will need to grease them.. The fitting will come with them, just grease them after you have them all put in.. All you need is that fork tool to pop the joint and a good 4lb sledge (makes the job eaiser than a light ball peen hammer)
Old May 19, 2003 | 08:33 PM
Victor's Avatar
Lee is right. Buy a big ass hammer - don't waste your time banging with a claw hammer.
Old May 19, 2003 | 08:52 PM
OneTrickToy's Avatar
I used a 4lb maul to seperate my tie rod ends. I'm sure it will be about the same doing the ball mounts.
Old May 19, 2003 | 10:13 PM
Thanks for the advice. I'll be doing the ball joints after I manage to install the headers and exhaust. The header installation was working out great until I broke a bolt. ugghhhhhh
Thanks again
Old May 22, 2003 | 10:32 AM
williemon's Avatar
I learned the hard way that I needed a BFH!!!! Bought one at sears the next day. Then the removal was easy and so was the install. Guess I need to grease them.....
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
