Intermittent charge and brake light
I was driving my 85 pickup this weekend and the charge/brake light came on for about 10 seconds. I checked my battery and everything seem to be okay. Later that evening I went for a drive and the lights came on again for about 5 seconds, This time I could see my headlights go dim. My guess is the alternator is going out. Should I be looking at something else?
yep .. I'd lay money on the alt. brushes as well ... I have done easliy a dozen of em ..
sometimes if you have been in the mud , it'll pack the brushes and they wont contact the armature causing a fault in the charge system .. sometimes preasure washing the alt will help loosen the packed brushes and free them up ..
Is it possible that a short somewhere else can cause the same outcome? (not trying to complicate matters with another possible suggestion....) The reason I bring this up is sometimes I hear a spark behind my instrument panel. I have the same problem as you and it only seems to happen when I first start up my truck (usually for the first 5 minutes or less) then the volt meter goes up to the top (I have a SR5 cluster int he truck.)
If it was the brushes wouldn't it be something that happened all the time and not just after initial start up? Night time is different and sometimes it take cruising the truck at about 40-50mph to get it to take a constant full charge when the lights are on!
John
John
My p/s pump was leaking .. drip drip.. right on to the alt .
brake and charge lamp came on . I did the shampoo , and wash .. and maybe , just maybe then , the key is to LET DRY .
works perfectly even a year later . just my experiance .
And for clarification this problem didn't exist until the power steering pump ws replaced.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
