Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Need Help: How do I get power to stereo headunit in 1st Gen
Old Mar 1, 2007 | 05:04 PM
AaronW's Avatar
I am installing a Kenwood headunit in my 1st Gen 4Runner and need to know how to get power to the headunit (The previous owner cut off all of the wires but one from the plastic factory connector).
I think the 12 volt ignition wire is colored GRAY. If so, I hook it up to the RED radio wire...right?
I think the 12 volt battery wire is colored BLUE w/ YELLOW Stripe. If so, do I need to hook the YELLOW radio wire to this also? Or do I hook up one or the other?
Thanks.
Old Mar 1, 2007 | 05:13 PM
waskillywabbit's Avatar
Sounds like it will be easier to just run new wire than guess as to what you have.
Old Mar 1, 2007 | 05:21 PM
AaronW's Avatar
Yeah Probably
You are right. I can wire it into the fuse box and be done with it.
Old Mar 1, 2007 | 05:26 PM
freshman's Avatar
installdr.com
Old Mar 1, 2007 | 06:08 PM
89macrunner's Avatar
or go buy a wiring harness adaptor from a car stereo place and be done with it.
I rewired my cars stereo and accesorries and added a second fuse box that carries only IGN power. makes installing crap so much easier and i never blow any fuses.
Old Mar 27, 2007 | 02:45 PM
bent240lv's Avatar
Could you go into more detail as to how you did this and what kind of fuse box you used? Thanks
Old Mar 27, 2007 | 06:48 PM
www.12voltguy.com fuse box.
i think he has a kit now..but you need a realy that will switch power to the fuse box when the key is turned on. Than just run the proper power wires and ground everything.
Jun 1, 2021 01:51 PM
91yotapup
Jul 27, 2015 07:19 AM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
CJ94yota
Jul 3, 2015 10:14 PM
