93 p/u front end to 4runner. side blinker dont work?
Old Feb 13, 2007 | 07:02 PM
str8_6's Avatar
i baught a 93 pickup with a 4 runner front end...forgive me if i'm stupid..but i'm sure the front corner lights are supposed to blink with the blinkers on.
it'll light up and stuff...but it just doesnt blink. i want it too.
is there a relay out or something?
Old Feb 13, 2007 | 07:03 PM
Elton's Avatar
welcome to yotatech... corner lights dont blink not sure how to make them blink but i wouldint mind if they did
Old Feb 13, 2007 | 07:10 PM
Elton's Avatar
we need more pics and details now
Old Feb 13, 2007 | 07:12 PM
str8_6's Avatar
thank you. and also...now tha ti think about it it makestotal since considering they are always on. i dont think it can serve as two functions.
well now i just have to figure out why one side has high beam working only. should be an easy fix. thanks for the quick response.
Old Feb 13, 2007 | 07:17 PM
str8_6's Avatar
those are it for now. details of the car. its got a 1jzgte motor. single t3/t4 turbonetics turbo. running right now 18psi. with 22mpg!!! im guessing its close to or around 350-400rwhp.
future upgrades: fab9 rear end with 4 link...taller rear end gears for highway pulls...and gt40-88
Old Feb 13, 2007 | 07:19 PM
Elton's Avatar
thats nice and its fast too and who owns the hummer h1
Old Feb 13, 2007 | 07:26 PM
91_4x4runner's Avatar
I don't know about serving dual function as parking lights and as blinkers, but you should be able to just tap them into the existing blinker lights.
Both mine are out
str8_6's Avatar
the hummer is the previous owners i think. i'm not too sure. its at a dealer though. i'm not enough of a ballar for that. i live in washington. so not too far away. any good yota meets?
as far as dual options on a single always running bulb...i was thinking maybe if you hook up a relay inline with the corner lights and then run the positive side of actual blinkers to active the relay hooked up to the one inline with the corners. that way its always on when you turn them on and then it'll just go on off when you signal. or just drill another hole for another bulb. i was just thinking its kinda dangerous if no one can see you signaling...they dont really look infront of the car...more on the side.
Old Feb 13, 2007 | 07:27 PM
rezrunner92's Avatar
I was searching wiring stuff today and read a thread where someone did this. It is really quite simple.
You need two sockets that use an 1157 bulb. The bulb is dual element and I think one is 25 w and the other 7 w. Just take the wires from the blinker and park light and wire the white ones together for a common ground. Then with a little trial and error you want the bright one to be the blinker. Now you have to modify the corner light cover with a dremel tool or something to accept the new socket. You could still have the bottom ones too if you just tap into the wires.
Old Feb 13, 2007 | 07:44 PM
str8_6's Avatar
sounds easy enough, but it'll just be hella bright on the side.
Old Feb 13, 2007 | 07:55 PM
I really like your truck. Must be a pain to change the oil ;-)
Old Feb 13, 2007 | 09:43 PM
str8_6's Avatar
thanks. i love it too. lol its actually not bad. except the fact that i do it every 2k. just like any other oil change if not easier. it'll always be easier then a damn previa
Old Feb 14, 2007 | 04:23 AM
joeynational's Avatar
Man i bet with that enigne in there it is a blast to drive.How does it drive?? Plenty of power i would guess,any problems so far?? I want to do an engine swap to just curious how you like this one??NICE TRUCK!!!!!!!!!
truckmike26
Jul 24, 2024 10:24 AM
Daneums
Jun 29, 2015 06:38 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
XtremeOff-Road
Jun 23, 2002 11:17 AM
94 First Responder
Jun 21, 2002 05:17 AM
