HELP!!!! Heater core installation
Old May 8, 2003 | 12:39 PM
Twisted4runner's Avatar
I need to know where i look at a step by step.
I have the book on this thing (22rtec runner) but I seem to have alot more stuff underneath the dash then the book shows.
Where can i look?
Old May 9, 2003 | 10:53 AM
I really could use the help i need to get this done
Old May 9, 2003 | 08:44 PM
HiLux_1990's Avatar
Well, I've done it on a 2nd gen vehicle... my little 'step-by-step' will have to wait a while though.
I take it this book you have isn't a factory manual?
There might be some info on the net about removing the dash on a 1st gen vehicle, but most of the write-ups seem to be for 2nd/3rd gen vehicles.
I reckon just tackle it head on... with some common sense you can carefully remove the various dash pieces without breaking anything. Just take your time, make notes so you know the order that things were removed... even take some photos. Also make sure all bolts etc. are labelled.
Once removing the passenger, driver and center dash pieces you then have to remove the instrument cluster and surround. Then the top dash pieces comes off, and the various heating ducts need to be removed.
Check that you have disconnected the heater hoses from the heater core (in the engine bay).
There should be a box-like assembly near where the transmission hump meets the firewall (this directs air to the different ducts). This assembly contains the heater core, so when you unbolt it take care not to spill coolant all over your interior.
Hope this is of some help,
Dave.
Edit: correction
Old May 10, 2003 | 12:28 PM
i already had a floor full of anti freeze it came out nicely luckily
thanks for the info i was looking for a trick thought this way i dont have to pull ther whole dash and the books i have are a chilton and a haynes
not factory
Old May 10, 2003 | 07:33 PM
HiLux_1990's Avatar
I'd be interested to know where it leaked? a hole in the core, or maybe the o-ring...
Old May 11, 2003 | 11:29 AM
goin to work on it right now ill let you know
Old May 11, 2003 | 12:47 PM
No it really is freakin imposible i just rebiult my whole engine and i cant even replace a heater core. well im sure i could its just a pain I NEED HELPFULL LITTLE HINTS OR TRICKS please and hurry i want to get it done.
Old May 12, 2003 | 07:15 PM
HiLux_1990's Avatar
Well my first little tip would be to take a deep breath
Where are you at? what's the problem exactly?
Old May 13, 2003 | 02:19 PM
how about those bolts right next to the windsheild
Old May 14, 2003 | 09:36 AM
HiLux_1990's Avatar
Are you referring to how the top dash piece (that runs down to the bottom of the windscreen) is attached?
Right along front edge are 5 (I think) plastic studs... the middle one is the most tricky.
If you have all the other bolts removed, carefully pull up the dash piece from along the windscreen.
Old May 14, 2003 | 10:51 AM
Ok its a first gen and all of them are bolts I need someone who knows exactly what to do here its really pi$$ing me off and im gonna break stuff very soon
Old May 14, 2003 | 05:43 PM
HiLux_1990's Avatar
Sorry dude, I forgot you had a 1st gen :pat:
Try over at 4x4wire...
the1998sr5
15
Jul 14, 2020 08:35 PM
Bucksnuff
Jul 31, 2015 07:09 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
jjrbus
Jul 19, 2015 02:06 PM
msane99
Jul 17, 2015 10:13 AM
