Dome Light
Old Jan 15, 2007 | 05:44 AM
Yotaboy's Avatar
Dome Light
I have an 88 Runner and an 86 Pickup and both of them do the same thing. The passagers door will turn on the dome light but the drivers wont. Anyone have same problem? Any fix? Ive tried to put a new switch in it also and they both work the key-in-ignition buzzer too.
Old Jan 15, 2007 | 06:01 AM
19RUNNER86's Avatar
i think thats the way it is.... mines the same way.
Old Jan 15, 2007 | 06:30 AM
amgraham's Avatar
Mine will sometimes work and sometimes won't.. I think it's a short on the passenger side because sometimes if my passenger gets out and slams the door the driver's side works.. very annoying.
Old Jan 15, 2007 | 07:20 AM
sdstud212001's Avatar
mine both work. just replaced bulb so i'm sure they both work on an 87 4runner
Old Jan 15, 2007 | 07:39 AM
rdlsz24's Avatar
Mine is the same. Passenger door will make dome light come on but driver's door won't. I figured it was just my truck.
Rob
Old Jan 15, 2007 | 07:52 AM
8yota9's Avatar
Mine works fine but bassenger side wen door is open buzzer wont make the noise lights work on both sides
Old Jan 15, 2007 | 08:29 AM
timebandit's Avatar
There might be a short somewhere, beacuse only the driver door should operate the key in buzzer.
Ok, if you look at the diagram, there is a diode in the circuit between the two switches (early model shown). The passenger door comes first in the circuit, hardwired to the door switch, then to the driver door, than through the diode. Looks like if the diode is open the driver door won't work at all. Looks like if that diode is shorted than either door will make the buzzer ring.
It is that or the seat belt timer/buzzer might have a malfunction inside if it. Hope that helps.
Old Jan 15, 2007 | 11:32 AM
Yotaboy's Avatar
Thanks for the help. I was a little misleading to begin with. My drivers door makes the buzzer sound only if the keys are in the ignition. Ive never had a seat belt warning buzzer. The dome light only comes on on the passagers side. With that said both door jam switchs are working. Where is this diode?
Old Jan 15, 2007 | 11:48 AM
timebandit's Avatar
Not sure on that. I will try to find out. I was reading off of the diagram in the Haynes manual.
Old Jan 15, 2007 | 12:23 PM
timebandit's Avatar
What I can tell you is one of the best investments I ever made was an annual subscription to Mitchell1 for dealing with stuff like this. But I never had it for the yota, that has been the beauty of owning it.
I will consider getting that now if I can help anyone else out with it. Don't use AllData, They stink.
timebandit's Avatar
http://www.eautorepair.net/
Old Jan 15, 2007 | 12:37 PM
timebandit's Avatar
Ok I am getting closer. I an looking at a diagram of my '94. This might be in the center of the dash if you have power windows. That is the RH door. THe LH door diode is in side the intergration relay on the back of the fuse box in the cab. It looks like the wires from the door switches go into that relay.
Ok, that is the seatbelt timer module as well. Hmmm... these have a habit of sprouting leg's because the idiot light stays on. I remember now, thats why I never fooled with mine. It is still lit on the dash after all these years. You are asking me to remember somthing that happened 9 years ago.
Old Jan 16, 2007 | 01:59 PM
timebandit's Avatar
How we doing, YotaBoy? Inquiring minds wanna know.
Old Jan 16, 2007 | 02:10 PM
Yotaboy's Avatar
Ive had the truck for 8 years and its never worked. I just got the 86 about 6 months ago and it does it. My friend has an 88 and his does the same thing. I was just wondering if somebody knows what the problem is. It seams common.
Old Jan 16, 2007 | 02:34 PM
timebandit's Avatar
Well I might. Take a look at what I said above, just see if it is missing. Mine has always worked fine.
Old Aug 19, 2007 | 09:07 AM
algranger's Avatar
if there is a short in the buzzer that might be causing your problem. the drivers side dome light switch goes through your buzzer. if thats not it maybe you could just go to radio shack and get some wire and a 7.5 amp in-line fuse and just re-wire it.
Old Aug 19, 2007 | 09:18 AM
aviator's Avatar
The seat belt warning buzzer has on that model I recall a switch under the driver's seat if you disconnect the switch the buzzer does not work. I know I disconnected mine when I used to be a K-9 guard in and out of truck all the time.
On the 94 the switch is in the latch and those cables can easily corrode and or break... again no buzzer.
Old Aug 19, 2007 | 10:06 AM
Jay351's Avatar
somtimes my switch gets sticky, just have to push it in a few times with my finger and its good for another week or 2
theking11863
Mar 19, 2016 09:36 PM
AkitaDog
Sep 1, 2015 08:05 AM
mr_manny
Jul 31, 2015 10:39 AM
TDonkey
Jul 26, 2015 10:14 AM
msane99
Jul 11, 2015 08:08 PM
