High pinion SAS Question
I have a 82' Toyota front end I am putting under a 88' Toyota pick up. My question is: Can you grind the front cover off and weld the front cover back on 180 deg. Then you could rotate you 3rd member 180 deg. and run Rev. cut gears. You would have a high pinion. Can you do this? If not than why? Thanks.
Dude, Pirate told you the right answer.
For the time, money and BS you are going through, you can buy a brand new, straight from Toyota housing and put the gears that you are going to have to put into it anyway. If you are worried about spending the extra 100 for bearings, find a different hobby.
Flying91
45
Apr 11, 2024 04:39 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
