shifter boot
Old Dec 23, 2006 | 01:47 PM
MMA_Alex's Avatar
shifter boot
I'm trying to replace the shifter bushing. I pulled the carpet out of the way, and I expected the shifter boot to just be tucked under the carpet. I see instead that it is connected to a metal plate screwed into the floorpan. Do I unscrew, and remove it to get the boots off or what?
Old Dec 23, 2006 | 02:34 PM
all_terrain17's Avatar
Yes, you have to pull the plate with the boots up off the shifters. Then you will be able to see transmission and the smaller, inner boot of the shifter...pull up that boot, press down on the shifter flange and rotate counter-clockwise (?I Think?) to loosen the shifter.
Then just pull the stick out and you will be able to see the bushing
mwisham
May 26, 2021 02:51 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
89YodaRunner
Sep 30, 2015 02:18 PM
irv
Sep 22, 2015 11:51 AM
