4.88 Toyota 8" axels
Old Dec 21, 2006 | 04:04 PM
94toyota4x4's Avatar
Question 4.88 Toyota 8" axels
Im probably beating a but I couldnt find it in search Ive seen it before but I dont know where, what toyota has the toyota 8" 4.88 geared axels? and will they fit my 94 toyota 4x4 pu? How much do these used axels run for? thanks
Old Dec 21, 2006 | 04:22 PM
95RunnerSR5's Avatar
there's a chart somewhere that tells you what gears you have based on the sticker in your door. they are most common in auto v6 4runners, i have them.
Old Dec 21, 2006 | 04:53 PM
slosurfer's Avatar
They were in V6 auto's with tow package and stock 31" tires. The third member will bolt right in. Not sure what they go for, I will probably be selling mine sometime this next year when I regear. If you didn't already know, the rear third with stock 4.88's can not be regeared, only locked.
Old Dec 21, 2006 | 04:56 PM
tc's Avatar
tc
anything from 90-95 with an auto and 31's will have them.
NOTE: The thirdmember for these gears are TOTALLY different - they have an offset pinion. There are NO other gears that fit in these thirds. Personally, I would get gears for your current diff - a lot more choices down the road.
Old Dec 21, 2006 | 05:16 PM
ok cool, but know one knows the price of the third member? I'm not going bigger than 33"s considering my longtravil kit works best with 33s, but just curious, why cant you regear yhem?
Old Dec 21, 2006 | 08:15 PM
pinnacle's Avatar
The 3rd member has a different pinion offset so that the ring gear doesn't need to be as thick. This means that no gears other than the factory 4.88's will fit.
Old Dec 21, 2006 | 08:19 PM
Sonofmayhem's Avatar
I could of sworn tc said that? if you get one keep your old one, When i go long travel on my 4runner im gonna run 35s but thats just me
Old Dec 21, 2006 | 08:44 PM
4Crawler's Avatar
Try http://www.car-part.com/
Old Dec 21, 2006 | 09:05 PM
pinnacle's Avatar
I'd like to run 35's but I'm already having a lot of rubbing on the rear wheel wells and a little on the pinch weld on the font.
Old Dec 21, 2006 | 09:28 PM
when the time comes itll be trail, dune truck only
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
nick b
Jul 11, 2015 04:38 AM
toyoda8488
Jul 5, 2015 10:18 PM
