Can't get my upper bumpstops off
So I have a 91 4runner 4wd and I got some low pro bumpstops, and as I was installing them I realized I couldnt get the stock upper ones off because they hit the control arm before the bolt was all the way out. The only reason for this I can think of is the torsion bar is over cranked. The guy I bought it from cranked them so much that the suspension was bottoming out on the upper bumpstop, so I un-cranked them some, but is it normal to have troube getting off the bumpstops?
I assume you mean the droop stops. Try to have a couple people sit on the fender and see if that gives you enough room to sneak it out of there. Otherwise you will have to back off the torsion bars to do it.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
aowRS
Sep 13, 2017 08:22 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
