Reubuilt or Remanufactured 3VZE?
Now that my HG blew on my 88 SR5 4runner and my 3.0 engine is toast, I have a few options to consider. I can go with a 3.4 but given that I have an auto I have to have the trans rebuilt for that. So no go on that since cost is somewhat of an issue. I would really like to put in a 1UZFE but that procedure is still fairly new and I really dont feel like messing with that. So I have two options left. I could get a rebuilt engine or remanufactured. I would be purchasing a rebuilt. Im not sure I would trust myself or someone else to rebuild mine. Unless anyone know anyone around the chicago area that knows the 3.0. Should I just spend the extra money and get a remanufactured engine or save and get a rebuilt?
pressure was building up in the valve covers. You could see oil spraying out of the pcv at idle. so at around 2500 to 3500 rpm you can imagine oil spraying out of the cap and pcv pretty good. and the pcv was also coated in burt antifreeze. does make sense since only the driver side was covered in oil.
The engine needs to be rebuilt. It has a pretty good knock. I am skeptic of putting in a used 3.0 This engine only had 150,000 on it. Monster, any idea of where I could mind a 3.4 and tranny and ECU or someone to rebuild my 340h to handle the 3.4 for $2300???? I can get a 3.0 REBUILT (not remanufactured), 3 year 100,000 LIMITED warranty obviously, shipped to my house and resend the old one back for $2300. A buddy offered to help my pull the 3.0 since he had done it once already. If im not mistaken the only drawback to the 3VZE is the HG and its a dog. Other than that the rest of it is pretty strong. A rebuilt 3.0 should run just as good as a remanufactured....no?
Just saw this post and thought you would like to take a look
https://www.yotatech.com/forums/f180/3-4l-2001-4runner-maine-100719/
www.orientengine.com, they should fit your budget and you won't be dissapointed
A guy from Kentucky said he will send me a money order for my '95 3.0 3VZE, but i haven't gotten it yet...i'll call him tomorrow to check on the status. If that deal falls through i'll still have this... https://www.yotatech.com/forums/show...=1995+3.0+3vze
And if he takes the motor i'll still have the R150F 5-speed tranny...make me an offer if you're interested...i'm next to Peoria, Illinois.
That 3RZ swap BigMike and Marlin did on MarlinCrawler forum looks Sweet...and Marlin just came out with a bellhousing to bolt a R150F up behind it...
And if you wanna ship an engine, these guys are good... http://www.highwayfreight.com/
We've been over this.
Anyhow, I rebuilt my 3vz-e to either match or exceed factory spec, but I have a stumble.
Its the engine wiring harness.
$602 from the Stealership.
Looking at my receipts for the 3.0 rebuild.
I could have purchased a low mileage 5VZE, the COMPLETE ORS conversion kit, a set of downey headers, heat insulation, and exhaust setup.
1988, 30, 3vze, 4runner, antifreeze, engines, oil, ors, pressure, rebuilt, reman, remanufactured, remanufacturing, spec, toyota
